I am trying to get my Dell Inspiron Laptop to connect to a Canon MF4700 Series printer. I added the printer to my computer but it has the yellow triangle with an explanation point in it indicating issues. I tried to resolve it but no luck. Any suggestions?
SOURCE: Firewire on Inspiron - Connecting Canon MD 120 camcorder
Browsing over the md120 specs, included should be a software disc for the usb connector, so it shouldn't matter whether you use an adapter or the 4 to 4 cable. This disc will have the drivers and software for using the camera in conjunction with your laptop. Have you tried this download for the camera.
http://software.canon-europe.com/products/0010449.asp
Also check out this link. Towards the bottom under additional features it lists software, drivers and utilities, and at the bottom under supplied accessories it lists application software/usb driver. Go to the store you purchased this at or contact Cannon support and get the disc that was supposed to be included.
http://www.einfo.co.nz/shop/product_info.php?pName=sony-dcrdvd908e-20x-optical-zoom-camcorder
SOURCE: canon mx850 series Error Number :
I had the same problem. I had moved my printer and when I hooked it all back up, there was an annoying clicking sound, the "in use/memory" light was flashing and there was no communication with my pc.
This is a tad embarassing, but if it helps someone, so be it lol. I had plugged everything in without looking.... my usb cable was plugged into the phone jack >.<.
Check all your connections.... then check them again ;)
SOURCE: Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
SOURCE: Inspiron 8600 does not charge batteries. Power
in these case u have to take one star screwdriver. carefully remove all screws n check the battery slot is it broken. if it is , den u have to change the slot.its just the connections problem. no prob with board. so dont worry ur works again.
