Where might I be able to find the codec and software for my z981 camera?
Floyd, Download and install Kodak Easy Share Z981 Digital Camera software. Check the attached links Z981 software download,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
KODAK EASYSHARE Z981 Digital Camera Firmware WINDOWS Operating Systems
http://resources.kodak.com/support/pdf/en/manuals/urg01118/Z981_xUG_GLB_en.pdf
Kodak Driver Downloads
SOURCE: kodak c613
Try Easyshare 6. 45MB d/l though
http://www.kodak.com/global/en/service/downloads/dln_ekn030260.jhtml?operatingSystem=windows_2000&downloadLanguage=en
SOURCE: Kodak Easyshare camera turns on and off
Hi, here is whats going on, if your M763 is powering on for 2 secs and the lense opens up then go's right back in, there is a 90% chance you got sand in the unit from say the beach ?
here is a test , when you press the power buttion watch the lense you will notice that the bigger part rotates as it comes out, what you want to do is give it a little help Lightly rotate it abit more just at the point where it normaly stops and go's back in, the cam will prob stay on and work like normal.
now the hard part 2 things to try, a can of AIR from walmarts try to blow out and sand thats around the rings, i did this and have fixed about 20 of these's now, on the others you will need to take it apart and clean the gears and mech of the lense housing then put it all back together.
hope this helps
IST tech
Chris
SOURCE: where can i get the right driver for my Kodak Easyshare M340?
You can get the drivers here.
http://www.kodak.com/global/en/service/downloads/dln_ekn036196.jhtml?pq-path=14649
Good luck and please rate
SOURCE: Lost software CD for Kodak easyshare C633!
follow the link and select your windows version.
http://wwwcaen.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=10/3905/6839/9637/9640&product=EKN032552
SOURCE: Kodak cd40 has wrong firmware. How can I fix this?
Try patching the firmware of your camera , get the update at www.kodak.com/go/downloads
