The error code "5:76" on a Whirlpool AWD/0 814D washing machine indicates a problem with the door lock. This issue can be caused by a malfunctioning door lock, a problem with the wiring, or a software error. The best course of action would be to check the door lock and the wiring connected to it, and also try to reset the machine by unplugging it from the power source for a few minutes.
This error is shown on the display due
to:-- Drain time exceeding
more then 8 minutes, the water valves
will stop functioningand the the water valves turns off and "F/02" will be
displayed on the screen. NOTE: in some cases it
has been noticed that 4 minutes the "Suds" error displays, and then 4
minutes later the F02 error displays. This Will Help.Good Luck.
This washer only has f fail code, they recommend you contact svc person for repair. Fail code for F02: F2
Door lock fault detected
The door lock on the washing machine has been detected as faulty or failed to engage correctly.
Check that the washing machine door has been closed correctly and is engaging the door lock correctly
Error code E09 means there is something the matter with the part in the washing machine control board that drives the motor. Fixing a control board error can be complex. You can try:
Switching off and unplugging your washer when you do this i suggest waiting about 5 minutes before plugging in since your machine can store energy even after a few seconds of being unplugged.
Checking the wiring and connections to the control board
The error code F-21 refers to Long Drain. The washer has sensed that it has not drained out completely and cannot go into further cycle.
If yours is a HE 2 washer, afer few minutes, Sd error will be displayed and then after couple of minutes F21 error code will appear. Water valves will be turned off and stops running.
If yours is a HE front load, when drain time exceeds 8 min, F21 error will be displayed. The water valves will be shut off and pump will stop running.
Generally, by re-storing the power to washer, it may fix the problem.
You may press the pause or the cancel button twice to clear the display.
You may have to double check the drain hose to see if there are any kink, clogs.
Also, you may unplug your washer, turn the circuit breaker off for 1-2 minutes and then plug it back in to check if it works. After this, check to see if the washer drains.
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Hello.
That code is telling you that the unit is draining to slow. After 15 minutes it is not below the low water level and will not spin out. The best repair for this is to replaced the pump on your unit.
Hi The error code F21 means LONG DRAIN If the drain time exceeds 8 minutes the water valves turn off. NOTES: After 4 minutes the “Sd” error will be displayed, and then 4 minutes later the “F/21” error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Possible Causes/Procedure 1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump. Please do rate the solution as FixYa and revert for further assistance. Thanks Rylee
