SOURCE: 2001 toyota tundra stalls when put in gear
If the engine stalls abruptly on your Cirrus, as if some one clamped
it, then I would suspect that the 'lock-up' function on the torque
converter of the transmission is in the lock-up position. That means it
is the same as popping the clutch on a conventional transmission car,
which cause the same stall. If you can't drive the car, I would call
around to several independent transmission shops to find one that is
familiar with the Chrysler 41TE transmission and that appears to be
honest. Ask if they have a diagnostic readout box to communicate with
the transmission control computer. If they do then have the car towed
there and let them try a readout. If they get a code 38 or 0740
(depending upon what year model you have there) then that would show
that the lock-up is the problem. If you are lucky the problem will be
with a solenoid switch or valve in the box on the side of the
transmission which can be corrected easily without removing the
transmission. Because this possibility (along with about 6 other
causes) is worth pursuing, I would want a shop that is not going to
talk you into a "rebuild" without first looking into all the possible
reasons for the lock-up condition so you aren't "taken for a ride".
So ask friends if they know a good honest shop and check them out as to
how well they understand the Chrysler transmission. You may end up at a
Chrysler dealer, but insist on their trying all the other possible
causes before authorizing removal of the transmission which is a very
expensive repair and may not be necessary.
SOURCE: Engine stalls when engage in any gear from neutral.
CHECK THE SIDE STAND SAFETY SWITCH IS OPERATING
SOURCE: engine stalls when clutch/brake pedal is released
Under the seat, there is a operator presence switch, if this switch fails, the mower will shut off when the brake is released, or put in any gear.
SOURCE: Clutch Malfunction and Adjustment
check clutch cable it could be either stretched or snapped if not you need a new clutch
SOURCE: as soon as i put the bike in gear it stalls with
This problem should be re-tagged gv650.
It's not your clutch, it's the kickstand killswitch. I had the same
issue.
If you look down next to your kickstand on the left hand side you'll see
a silver switch (looks like a mushroom), follow the cables up to the
front end of the chasis near the sump and you'll find a black connector
with two wires coming out of it. You can either bypass the connector
using a piece of wire or just do what I did and clip the wires, wind
them together and crimp them in a connector.
Start your bike and hey presto - problem solved.
Hope this helps.
Testimonial: "Great help.did not need to cut wires just knowing what to look at i found the switch was stuck in. So it took about 15mins to remove lube reassemble. "
