While watching a television program the tv went off and now it will not turn back I'm. The red power light flashes in the bottom left
SOURCE: Samsung 42" Plasma spn-4235 Went black
SOMETHING IS LOADING DOWN THE POWER SUPPLY...COULD BE THE Y-SUS BOARD OR UPPER OR LOWER Y-DRIVE BUFFERS...TAKE THE BACK OFF SET..GIVE IT THE SMELL TEST AND EYEBALL THE FLAT I.C.`S ON THE THIN BOARDS TO THE LEFT OF Y-SUS BD. IF NO BURNING SMELL AND NO CRACKS ON THE FLAT I.C.`S ...TRY REPLACING THE Y-SUS BOARD...NUMBER ONE PRIME SUSPECT...DO NOT POWER UP SET WITH BACK OFF UNLESS YOU ARE QUALIFIED SERVICE TECH...JOE ACE
SOURCE: Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
SOURCE: samsung lcd tv ltm1755b won't turn on (power light stays red)
Problem: Samsung LTM1755B with only a blinking yellow LED when you try to turn it
on.
Solution: I just had one of these come in. I opened it up, and found
the U501 capacitor a little suspicious looking, in that it had a
deformed top. It was a 470uF 16V electrolytic 105degC 10mm x 12mm. I
replaced it with a very good quality 1000uF 16V electrolytic 105degC
10mm x 16mm Nichicon UHN1C102MPD. After that repair, when I tried to
turn it on, the LED was yellow for a second, then green, then I got a
picture, and it appeared to work great. I then asked the owner a week
later how it was working, and they said it was working just like new!
I had a 26" Samsung LCD that wouldn't turn on, and the red light stayed on too, so I knew it was getting power. I found some info out there and figured out how to fix it. Also made a video to show others. I'm a complete newb so if I can do it, I know a lot of others can too. Make sure you research stuff and be safe when fixing it. I take no responsibility if you mess up your own TV! But like I said, I fixed it, so I figured almost anyone can. Also, it only cost me $1.40.
http://www.youtube.com/watch?v=vWKlex7kA7A
SOURCE: I have a 42" Samsung
This clacking and clicking noise could have been coming from a capacitor going bad in the tv. If this is the case where the tv will not turn back on, I would suggest calling samsung to try to get a replacement or get the tv serviced. Trying to replace bad capacitors can be a tedious job and requires knowledge of soldering small components. This may also void your warranty if you still have coverage.
