SOURCE: hit a light pole in parking lot got bad alignment
Thats an impossible question to answer. First you must determine what is bent and then replace it. When the shop checks the alignment, thats when you will know if it can be aligned.
SOURCE: need to find out the numbers of the camber,when
CASTER RANGE DEGREE 2 1/2 P 3 1/2 P - PREFERRED SETTING 3P -CAMBER RANGE 5/16N - 11/16P- PREFERRED SETTING 3/16P - STEERING AXIS INCLINATION DEGREE - TOE IN INCH O STEERING AXIS INCLINATION DEGREE 12 13/16P.
