Most newer printers have a regular hard drive, which retains most information that has been entered. It is advised to remove the hard drive when disposing of the printer.
Not all models of the Ricoh Aficio have a hard drive, but if your model has it, it will be located on the rear left side of the machine, near where the network port and phone jack (if you have the fax option) are.
To get the hard drive out you would remove the big rear plastic cover, then the gray metal cover beneath that, and then disconnect the hard drive from the controller board that it is mounted on (with the copier off, of course).
Ricoh offers a Data Overwrite Security kit, but I don't think it will work with the 1022. Your best bet is to remove the hard drive, attach it to a computer, and wipe it with a program such as CCleaner or Hard Disk Scrubber (both of which are free to download).
No, the 1085 needs the hard drive to run. You're better off trying to find a newer copier anyway -- the 1085 is ancient and you probably won't be able to get a lot of replacement parts for it. You can probably find a 2090 or 2105 for a good price -- those machines are still supported and will run for a long time.
If no error code comes up then you have a hard drive error in your Print controller.
Remove the back cover (unplug machine) remove the cover for the controller (controller is in upper right on rear side of machine and disconnect the hard drive.) Plug machine back in and see if it comes to ready. if so replace the drive, if not controller is bad.
If you have a Savin 2555, you need type 5570.
If you have a Ricoh 1055, you need type 5105D.
They are both the same machine, however the toner cartridge is model specific. ie; use the Savin type toner for Savin machine only and Ricoh type toner for Ricoh. There is a difference between the cartridges and the way each fits the feed mechanism.
