Question about Sony DVP-SR200P DVD Player
Sony dvd player model # DVP-sr200p tray won't open. The face of the tray is off but I can not find the tiny hole to open it. Can you tell me or show me where it is?
6ya staff
SOURCE:
njvinod
Vinod Kumar
  • 1462 Answers
SOURCE: Hi, I need to unlock
THere was some problem, with the chat...I was not gettin gyour messages
1.Switch on the player
2; Pop open the CD compartment
3. Enter the following code (using the remote): 2812
4. Highlight the region
5. Change to 9 (for Multi-region) using the 'Enter' button
6. Hit 'Clear' to exit
7. Pop in a DVD and enjoy!
Posted on Sep 19, 2009
Paul Hutchinson
  • 909 Answers
SOURCE: I purchased dvds from ebay and they will not play
Turn on the unit with the remote controller, Wait until "no disc" appears in the unit's display. Press the keys: PAUSE, 3, 1, 4, 1, 5, 9. And "CODE" will appear in the display. Press the number key that corresponds to the disc zone you want to play within the next 5 seconds:0: All regions / 1: Region#1 / 2: R#2/... and so on. Then, within 5 seconds, press: PAUSE, POWER... and voilà. If you don't have good results, disconnect the equipment and repeat.
Or
Put your player in standby mode and then enter: [[0] [ENTER] Default Default region code [1] [ENTER] or [UP] [ENTER] Region 1 [2] [ENTER] or [RIGHT] [ENTER] Region 2 [3] [ENTER] or [DOWN] [ENTER] Region 3 [4] [ENTER] or [LEFT] [ENTER] Region 4 [5] [ENTER] or [TITLE] [ENTER] Region 5 [6] [ENTER] or [DVDMENU] [ENTER] Region 6 [7] [ENTER] or [RETURN] [ENTER] Region 7 [8] [ENTER] or [DISPLAY] [ENTER] Region 8
Or
Put player into standby modes by pressing power button on remote control. Then press Title button. Press Clear button. Press Power button.
I found these codes for all the other DVP-SR series players, yours was not listed but I thought was worth a try.
Posted on Apr 14, 2010
sonofsong
SOURCE: How to turn off the closed captions on my sony dvd
I had the same problem so i simply turned off the CCD on the tv itself and no more captions!
Posted on Jun 12, 2010
Mr Solutions
  • 129 Answers
SOURCE: cd compartment wont open and it is locked dvp
Ensure the child lock feature is disabled. Try Power resetting the Player.
Turn Off the player and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation.
If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons or the RETURN + ENTER+ POWER buttons.
If the issue still persists, service might be required.
Posted on Jul 26, 2010
muntejaya
Muntejaya Ginting
  • 10421 Answers
SOURCE: sony dvd player DVP SR200P need to unlock region
Hi, Please get the code here :
www.dvdexploder.com/
www.download-info.com/dvd/index_new.htm
www.220-electronics.com/dvd/ht.htm
www.videohelp.com/dvdhacks
Jay__OKmnu8990
Posted on Feb 24, 2011
I would like to know where the tiny hole in the front of the tray is?
I can't help with a picture of the same unit as you have, perhaps you can post a picture of yours with DVD face removed (there isn't such a hole on the intact unit). so that I can inspect it. Your DVD player may not have such a hole. If you consult your user manual I think it tells to you to take the unit to a Sony service centre, but you could the support section of their website. Meantime I attach a picture of computer DVD player, with the hole inside a white ellipse that I have marked in between the LG logo and the button. It's not very visible, being less than 1 mm in diameter (just wider than a paperclip)
May 06, 2014 | Sony DVP-SR200P DVD Player
Sony dvp-sr750hp unlock
sony dvp-sr750hp unlocking tray
Nov 16, 2012 | Sony DVP-SR200P DVD Player
My sony dvp-sr200p, disc tray is not opening?
Hello
Try the mechanical release;
Look for a very tiny hole in front of the drive; use a paper clip poke through that hole, apply a little pressure and push. The tray should pop open.
there might be a panel that covers the tray, and you won't see the tiny hole. If that's the case, just use your fingernail to pry open the panel, which most likely will pull out (not off), and you'll then see the hole. Once you push the straightened out paper clip into the hole, the tray should come out enough for you to pull it out the rest of the way.
Sometimes the CD drive doesn't open because the case is misaligned. Try pressing on the center portion of the drive when it is attempting to open!
Apr 11, 2011 | Sony DVP-SR200P DVD Player
Cd compartment wont open and it is locked dvp sr200p sony
Jul 26, 2010 | Sony DVP-SR200P DVD Player
I need to unlock the DVP-SR200P to play all regions.
Tell that to my DVP-SR200P ¬_¬
I just bought it, It's regoin 4 and it doesn't play other ones.... I just found out!!!!!
MONIQ
Oct 09, 2009 | Sony DVP-SR200P DVD Player
My sony DVP-SR200P player has a disk in it and it won't open and keeps saying this operation not allowed or something like that. I have tried everything to get this dvd out
Try this. With the power off, press and hold the open button on the units face until it opens. This works with many Sony players and Sony recorders when there is an error. Hope this helps.
Jul 16, 2009 | Sony DVP-SR200P DVD Player
Sony DVP-SR200P DVD Player Logo
315 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
