need diag
Dani, Check the attached links,instruction and guides shows all cooling components in diagram and part #'s, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
? 3:46
https://www.youtube.com/watch?v=sD2G-NzycvU
Aug 11, 2011 - Uploaded by rsarp
1994 Mazda MPV timing belt replacement, 6 cylinder DOHC 3.0... engine so the valves would not be bent ...
4 hours ago - how to replace the timing belt on a 1994 mazda 929 3.0 dohc 24 valve... I have a 2000 Mazda 626 4cyl 2.0 liter DOHC engine replacing the timing belt, what ... 2004 6s, 3l. where is the canister purge valve solenoid located?
4 hours ago - where are the timing marks on a 1994 mazda 929 3.0l - Mazda Cars ...1994 Mazda E2000 Cam Timing Mark Positions to Replace Timing Belt ... on a 1994mazda v6 dohc 24 valve engine How to align the timing mark on the ...
The thermostat is located in the flange where the LOWER radiator hose attaches to the engine. Three bolts secure it to an odd looking plastic pipe assembly.
Follow the hose running towards the engine from the air filter and you will come to the throttle body. This is where your throttle cable is also located. On the opposite side of where the throttle cable is you will see wires running to a sensor, this is your throttle position sensor.
