When i connect dlink dir 600 to my wi tribe router it says local area connection limited or no connection
SOURCE: cable modem + dlink router
Your modem needs to be rebooted in order for your router to pull an IP from the modem. To do this, look for a little hole in the back of your modem and use a pen to push the button. Wait for the reboot to finish and then try again in about 20 seconds.
SOURCE: Broaband link
Ok, thank you for clarifying.
It seems like the settings on the 1707 have been reset.
On this modem, while connected, type "homeportal.2wire.net" without the quotes.
*note:you may have to enter your password. if you never set one and it asks you for one, click on "I still can’t remember the password". Follow the instructions.
They should be able to give you your info.
If not, comment back.
check the firewall on your laptop sometime these block it from connecting
SOURCE: D-link Router DIR-625 resets itself
You need to open the router's setup page (admin page) http://192.168.0.1 to enable the wireless security
