How do I remove a stuck toner cartridge from a Brother TN630 printer
If you have a stuck toner cartridge in your Brother TN630 printer, here are some steps you can try to remove it:
Turn off your printer and unplug it from the power source.
Open the front cover and carefully remove the drum and toner assembly.
Locate the release lever on the side of the toner cartridge and push it down.
Try to gently pull the toner cartridge out of the drum unit.
If the toner cartridge is still stuck, try gently wiggling it back and forth while pulling it out.
If the toner cartridge still won't come out, try using a pair of pliers to grip the cartridge and pull it out. Be careful not to damage the cartridge or other parts of the printer.
Once the cartridge is removed, clean any debris or residue from the drum unit and the cartridge itself.
Reinstall the drum and toner assembly back into the printer, making sure it is securely in place.
Close the front cover and plug the printer back in.
Turn on the printer and test if it is working properly.
If these steps do not work, it may be best to contact Brother's customer support for further assistance or to schedule a repair.
