Sony Dvd Home Theater Remote Control Rm-adu005 Dav-hdx265 Dav-hdx266 Dav-hdx665 Logo
p
pennoyer_2j Posted on May 07, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dav-hdx665 only plays certain DVDs, why. - Sony Dvd Home Theater Remote Control Rm-adu005 Dav-hdx265 Dav-hdx266 Dav-hdx665
Mohamed Alazhary
Level 2:
New Friend:
  • Expert 96 Answers
  • Posted on May 10, 2014
Mohamed Alazhary
Expert
Level 2:
New Friend:
Answers
96
Questions
0
Helped
39320
Points
130
Check the region code. Or the laser beamer is dying.
I have a Sony DAV S500 AV system and with certain DVD and with the volumn just over 20 (not really that loud), the system shuts down and PROTECT shows in the message window. I read somewhere on the web...
If the subwoofer and other speakers were included with the system, THAT is what they're designed for. Mixing and matching with other products is usually discouraged if not forbidden.
http://audio.manualsonline.com/search.html?q=Sony+DAV-S500
If the problem returns with connection of the sub it may be defective or on its way out. Internal damage to the voice coil from being overdriven could have melted or worn through the insulation and it would cause intermittent undesired electrical contact or load variation under certain conditions, like high volumes.
If your speaker level settings are unusually boosted for the sub you may be overdriving it.
1helpful
Hi!! I have a SONY DVD player(model- DAV DZ150K)...Recently it has refused to play DVDs (it says "cannot play this disc") and only plays VCDs and ACDs...please help!!!!
I have 1 sony DVD Model No-DAV-DZ150k .When i have select DVD mode so dest error show on VFD Disply .Pls tell me what is problem in DVD.
My sony dvd player DAV-DZ720 does not play many dvds
i want sony home theater dav-dz720 english user manual book
Home cinema sony dav f200 error cde c:13:71
ive got a sony dav f200 home cinema system,it lets me play music cds but trying to play dvds(not copied or american) it comes up with and error code c:13:71. what does it mean?
2helpful
Cannot play dvds
Get a can of compressed air and spray some air in there. Your lens may have become dirty. Has it ever played DVDs? How long ago?
2answers
'PLAYBACK PROHIBITED DUE TO AREA LIMITATIONS'
Check area code at your unit and usualy its printed at back side. If your unit belongs to code 1, it will play only region code 1 dvds and so on other codes.
Sony DAV-BC150 System
I have this same problem. Plays music CDs fine but DVDs do not work. It recognises the DVD tries 3 times to play it displaying "Reading" and then moves on to the next available disk. Any suggestions?
SONY Model No: DAV-D150G DVD play problem!!
dav-dz100 a disc cannot be ejected and locked
Playing burnt dvds in black and white
Cause: You are trying to play a DVD with NTSC-standard on a PAL-videodevice. Solution: switch your video-device to NTSC-standard or to "AUTO". Explanation: I had this "Black&White" problem after I played a DVD which I downloaded from Internet. My video-device (beamer) was set on PAL and gave black&white pictures, but when I switched it to "NTSC" the problem was solved. Apperently the Sony DAV-DZ100 switches automatically from PAL to NTSC when needed.
1helpful
Not reading all DVDs
This problem has been getting more and more of a popualar complaint and there is no real setr answer for it as I have found that when i see this happening theres an alighnment issue, a foggy lens, dirt or hair in the carrage assembly track or worm gear, and also a weak laser assy. Good Luck
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
