This unit has always been on a surround system and worked fine. I have gone into the sound menu and changed the system to internal speakers. No sound. Have checked to ensure it is not in mute and have also set the volume level to 35, still no sound?
You can go to your menu and select the test tone just to see if your speakers are operational, if not replace the speaker. If you have test tone, then check your input connections. If everything is connected correctly then you need to replace your main board and that should resolve the problem.
hi Darryl,
your TV does have internal speaker "Built-in speakers with life-like BBE high fidelity surround sound". If your speakers are not working after verifying all your connection, I suggest you replace the main board. This should correct the problem for you. I highly doubt that your speakers are blown.
I am trying to use the internal speakers and the set does not have a test tone. Even though though this plasma has a setting for internal speakers I'm not sure if it has internal speakers?
