if your Lenovo idea tab a1000 got freeze or hang at any stage.
there is no option to remove battery it is in built.
don't try to switch off tab. leave it for 30 sec. if automatically problem not solved.
just connect with charger and press power button.
its done 100%..
try it.
PLEASE TRY TO RUN SYSTEM RCOVERY FIRSST USING A DISC THAT CAME OU WITH YOU COMPUTER. THIS WILL DETERMINE IF THE PROBLEM IS WITH THE SYSTEM OR THE EXTERNAL HARD DRIVE.
Does the flash fully charge? If so, it may be that the flash tube is faulty and will require replacing.
This should be done by your authorised Samsung repair centre.
That is what casio calls a lens error. You will have to send it in and have it fixed. The cameras don't do well even when dropped from that short distance.
Call repairs at 800-706-2534 and keep choosing option 1. Tell them that you talked to tech support already otherwise they will try and transfer you to their tech support.
