Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Jun 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool duet front load washer has standing water inside
Whirlpool duet front load washer model WEW9200SQ02 gets standing water inside between loads? why? and how do you fix?
  • l_thiel Jun 22, 2009
    How do you remove the front panel?
Anonymous
Level 2:
Sergeant:
  • Expert 212 Answers
  • Posted on Jun 22, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
212
Questions
Helped
74901
Points
630
Take off bottom panel of washer. unscrew front plug to drain pump. clean out
  • Anonymous Jun 22, 2009
    should have two to four 1/4 inch screw at bottom. remove and pull panel out.
2helpful
Can you stack this washer and dryer?
You can stack, will you be able to reach. Racks can be made to stack any normal washer and dryer.
Duet front load - water fills while door is open!
This is a leaking solonoid valve.
The valves are located just inside the machine where the water supply hoses attach.
  • Remove the power plug
  • Undo the top lid of the washer
  • The valves will have some internal pipes clamped on their outlets. Remove the pipes.
  • Dry the valve outlets with tissue.
  • Turn on the water supply to the washer (if it was off)
  • Watch the open valve outlets for seepage.
There may be between 1 and 3 valves depending on the model.
You should be able to replace the leaking valve quite easily.
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
I have a whirlpool Duet Front loader Washer Model GHW9150PW4
there is a book inside the washer in bottom or back that gives you the trouble codes
2helpful
Washer tub slowly (over several days) gets water inside
yes this is more than likely a leaking inlet valve, to confirm turn of water at wall valves
2helpful
Standing water in the tub
bad inlet water valve --turn water supply off and watch to see if machine continues to fill with water --suggest removing inlet water lines from machine and inspect the strain screens on the machine for sediment build up if so clean
Stale water in whirlpool duet front loading washer cannot see water but can hear it if you move the inside of drum
Saw in my local newspaper... Whirlpool won't tell you to maintain by unplugging the machine and removing the front bottom cover of washer (3 screws) ...you will see a valve cover in the center right in front of you....Get towels ready to soak up the water that will spill out when you open this. Remove it and clean the plastic filter and any debris you might see inside then put back together. It worked and wasn't hard to do but now I have other issues with the machine errors and such....I think I'll go back to the old washers minus the electronics.
Gentle cycle did not complete leaving water standing in the tub.
Whirlpool downloader washer model number GHW9150PWO
PROBLEM Gentle cycle did not complete leaving water standing in the tub
8helpful
Whirlpool Duet washer fills with water by itself
sounds like a faulty water inlet valve, not seating properly after closing the valve.replacing the valve is the only solution to this problem, in the meantime you can turn off your water supply in between doing loads.
not a bad habit to get into!!!!
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
