Question about HP Pavilion dv6835nr Notebook
HP Pavilion laptop screen has gone black/blank
HP Pavilion laptop screen has gone black screen/blank. If you tilt the screen, you can see the display is there and everything is working properly. The only way to get the screen to light up again is to press on the bottom of the screen. Does this mean something is loose? How would you suggest I fix this? Thanks in advance.
  • 2,229 Answers
If you mean that when you put pressure on the bottom of the screen it lights up like it is supposed to, there might be a loose connection in the LCD power converter, which is located just under the bottom of the screen. If it was "broken", then you would have no effect when you push.
Before replacing the screen, I would take it apart and check the connections. It will be obvious where the power converter is. All the rest of the enclosure is just the LCD screen.
What you are missing is a constant connection to the florescent backlight.
Posted on Jun 22, 2009
    Sergeant:
  • 220 Answers
You can either use an external monitor for working with the laptop or talk to HP for replacement.
The best option is to use external monitor to backup data before sending it to replacement.
Good luck
6ya staff
SOURCE:
The screen went blank, after nine of ten years. I am using an extension screen, but this pretty well stops the portability of this unit.
Take the laptop into a dark room.. I.E. no lights at all, pitch black.. Then see if you can see anything on the screen.. I tell my customers to take it into the bathroom and shut the door.. If you can see something on the display then it is the backlight inverter that is out and needs to be replaced. If at that point you still cannot see anything then you would be looking at replacing the screen in it as it has gone bad.
Aug 13, 2013 | HP Pavilion Dv9000 Dv9009us 1.3mp Web-cam...
My HP Pavilion G6 laptop screen turns on and then goes blank (black)
When the screen turns on does it show anything or does it turn on and go to black?
If it goes to straight black it could be two things typically.
1. The LCD screen is having an issue. Connection cable / LCD screen itself.
2. The Graphics Card has gone out.
Jan 19, 2013 | HP Pavilion G60-235DX notebook
HP Pavilion tx2000 monitor not display, all the light on execpt the monitor blank
Sounds like your display has completely gone out. If your device is under warranty, you should try to contact HP as soon as possible and request that your device be repaired.
You could try swiveling the display around or tilting the laptop at unusual angles--if there's a loose wire or connection, the display might flicker on.
Mar 01, 2011 | HP Computers & Internet
Hello sir, When i switch on my hp pavilion dv2000 my display is very very very dim almost black we cant even see the image but when it is tilt somewhat we can see the display that too very dim...
Hi,looks like the flex(screen connector)is have partial contact,try removing it carefully and fixing it back,ie if you can do these,otherwise take to an Expert to do these for you,if after these it still is very dim,then i'd suggest you get yourself a new screen.
Jan 04, 2011 | HP Pavilion dv2000 Series Laptop Full...
Hi, I have an HP Pavilion DV7 laptop. When I turn on the computer everything seems to be working but the screen is blank. Blank meaning black and/or colorless without light. Thanks!
Borrow a monitor and plug it into the side of the notebook to verify that the computer still works. If it does then the screen has gone out.
Jan 28, 2010 | HP Pavilion dv6000z Notebook
Powers on but screen is blank
GO TO THE BIOS SCREEN AND CHECK IF U HAVE ANY DISPLAY .. U CAN DO IT BY TAPPING F10 DURING START UP ... IF YOU DONT GET ANY DISPLAY .. ITS *********** BOARD GONE BAD
Jan 25, 2010 | HP Pavilion TX1000Z Notebook PC
My hp pavilion dv6950ei does not display...it shows blank screen even on lcd...it remains the same...
This sounds like the lcd monitor cable has gone bad, or the inverter or lcd screen have gone out.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 12, 2010 | HP Pavilion dv6000z Notebook
No it suggests you have a bad screen and it needs replaced
Jun 22, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion dv6835nr Notebook Logo
199 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
