A friend gave me this turntable,but she can't find the software that came with it.Went to ION site to get it.They wanted the serial #.I punched it in,and it was correct,but they said it wasn't.I would like to make it work.I'd appreciate if some one could help me with this.
Thanx
Steve
Hello
USB audio turntable can be found on this site: Driver Update. have a nice day
Drivers are not necessary. Connect the TTUSB to a USB port on the computer (not on a hub or in the front panel) and the device will install as "USB Audio Device" From there, you can use Audacity (freeware from Sourceforge) or the Mixmeister EZ Vinyl Converter software they ship with the unit to record.
Here are direct links to the software and documentation:
EZ Vinyl Converter (PC)
EZ Vinyl Converter (Mac)
Audacity Software Guide
EZ Vinyl is pretty much get-up-and-go. The guide I have is basically "start it up, hit "record"
Note: when you hook up the TTUSB, it will become the default output device. You will need to go into the sound options in XP and Vista to change the default output device to your usual audio devices.
Had terrible problem finding the solution then started 'fiddling' with the head to ensure the 'needle' was fitted corr!ectly. I tightened up the small silver 'collet' behind the head and it started working perfectly
I got one of these turntables last year and am just now getting around to using it. Only trouble is I can't find the serial number to start up the software. Where did you find in on yours?
Thanks,
Lauren
