I have a John Deere L110 that won't start. Mowed grass then parked it and it wouldnt start. These are all of the things we have done:
New spark plug, solinoid, all 3 safety switches, battery terminals...
problem could be: brake pedal is not depressed; PTO is engaged; battery terminals are corroded; battery not charged; blown fuse; or fusible link in starting circuit is blown.These are the Most Common Causes for your Problem. Recheck your voltage of the battery and then check it under a load....Take a Jumper Cable Set and Attach the Positive Lead to the Positive Post of the Battery. Take the Other End and FIRMLY Touch the Large Post of the Soleniod on the Starter Side. If the Starter Turns the Engine, then Check the Voltage from the Ignition Switch to the Soleniod. If the Voltage is Going From the Switch to the Soleniod When the Ignition Switch is in the Start Position, then Replace the Soleniod. If No Current from the Ignition Switch to the Small Post on the Soleniod, then The Ignition Switch is Bad ....Hope this helps
