SOURCE: Router says connected but I can't access the internet
Ok... I see two people here with what appears to be the same issue, however "Guest" seems to have a more specific problem. I want to clear that up first.
To "Guest":
You are confusing your ETHERNET (Wired) connection with the Wireless connection. If it says that "a cable is unplugged" then it is refering to your ETHERNET connection. (Also known as "Local Area Connection" by default.) If you are not going to be connecting your laptop to the router by way of an ethernet cable, then you can actually disable that ethernet port by right-clicking it in the "Network Connections" window and selecting "Disable". (This is how it is done in Windows XP. Windows Vista is a little trickier for some reason.)
If you are showing a strong signal after that, it means that your Wireless adapter is still working correctly. Make a new attempt at connecting to the wireless router by finding the name of your router in the list of available wireless connections and clicking Connect.
If your router's SSID (name) does not show up in that list, then it may be secured as per the default settings. The newer models of the WRT54G router have a button on the front that you can press to temporarily disable wireless security so that you can log onto the router and make your settings. Look on the front of your router for the "CISCO" logo near the front-left. It is illuminated by an orange glow. This is to enable SES or "Secure Easy Setup".
Pressing this button will turn it white and it will probably blink, too. While this light is white, you should be able to find the router on the list. But it will be called something different. It should have random numbers and letters as the router's ID and should show a fairly strong signal.
This is a temporary connection. This gives you enough time to log on to the router and change it's settings before the open connection times out.
To make all of this as easy as possible, I would make sure to do two things:
1.) Use the RESET button on the router to set it back to factory defaults.
2.) Make sure you unplug your cable modem and plug it back in before reconnecting it to your router.
3.) Make sure that you leave all default settings for all network adapters in Windows.
4.) If you have connected your laptop to other wireless networks called "linksys" in the past, it may have the settings of those previous routers in the history that Windows keeps for all wireless connections. You can find that list and CLEAR IT by right-clicking the little icon in the lower-right corner of your Windows task bar and selecting "Open Available Wireless Networks" and finding the list on the left side of the next screen.
I can't advise on much beyond that until I know the results of this procedure. But it sounds like both of you are having the same issue. Here's a tip:
For now, ignore ANYTHING that says, "Local Area Connection". That has NOTHING to do with wireless. That is the WIRED connection. (Ethernet.)
I'll watch here.
Cyryl
SOURCE: Linksys Wireless WRT54G vs. WET54G
For what it is worth, I fhave found streaming video does not function well using a wireless connection. The options of multipale routers will work as long as you configure them as to not have conflicting IP address assignment's via DHCP, and the routers do not have matching IP address's. Never fear all is possible with paticence. BPCS
SOURCE: Can't connect Toshiba laptop to Linksys Wireless Routher!!
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. here are the steps u need to do:
1. your desktop computer can connect to the internet if u pull up a browser. First we need to access the setup page of the router by typing at the url of the browser:192.168.1.1
2. it will show the setup page of the router. u can set the router on the specific internet setup that u have. since the router us setup already u have the internet connection thru the desktop computer using a wired connection..
3. Look for the wireless settings of the router and create first a ssid or wireless network name then u can as well set the wireless security by selecting wep, wpa, wpa2 then tkip.
4. once your done with the wireless settings, check now the settings for the toshiba laptop computer, some laptop wireless network adapter comes up with a software, I have a dell laptop and I dont use the software for the wireless adapter to connect to wireless, I disable it and use the wireless zero configuration of microsoft windows. u can check the wireless adapter software at the lower right corner of the taskbar, u can disable it by right clicking it and there will be an option to select to disable and sometimes there is an option as well to use the wireless zero config. given u already disable the software and there is no option to use the wireless zero config. u can click on start then run and type services.msc and the services tab will pop up and scroll down to the button of the services and u will see the wireless zero config, just right click on that line and enable it. once its enable it will show a wireless icon on the lower right of the task bar its like a little double computer icon, if it does not show, check on ur laptop maybe the wireless switch is off, the switch is located on the sides of the laptop or on the key area or check on ur manual on how to turn on the wireless switch if u cant locate it. once the icon show, right click it and select on view available wireless network and it will list all available network in range included the wireless network that u created, just select it and connect, then it will ask the password, type the password and connect. u should be connected.. I hope this will help u.. pls feel free to get in touch if u have any concern.
SOURCE: I am using linksys wrt54g2 V1 wireless router. The
/Sometimes you have to call the cable company and they will reset the modem online for you. After you have done the whole powercycle bit, you have to restart the computer. Make sure all the other computers or laptops are shut off when you reset.
Linksys wireless router has many bugs: connection issues like no connection or constantly having to reset the router. It isn't compatible with many network adapters. Hope this helps!
SOURCE: WRT54G2 wired desktop fine, can't connect to wireless.
Hi Seth6025,
Try without using Wireless Encryption (password).
Try changing channels; default is 6; try 1 or 11.
Change your SSID: personalize it
SSID broadcast: Enable
Check the advanced wireless settings and make sure MAC filtering - DISABLED.
Reset the Linksys router by pressing RESET for 30 seconds should everything fails and re-configure. Firmware is another consideration BUT this is just a new release.
Regards,
Angel
