The machine wont start and we tried over and over again but still wont start. all of the buttons work but when we press the start button the machine wont start
SOURCE: LG Intello washing machine, model: WD12235 Front Load
Why dont you people read the user's manual? You wil learn abt your machine, to a certain extent. Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds. Works for other machines...............And please rate me if helped................
SOURCE: buttons not working on lg washer
Could also be that the board has not been screwed on tight enough so it has a bit of play in it. You would have to check to see if the boards that are behind the display panel are on correctly.
It could also be a defect in the board.
Sgt 48
SOURCE: cant rurn on my my washing machine
Have you tried a simple reset, by unplugging, waiting several minutes and then replugging it in? Is it plugged into a gfi outlet? is the little red button pushed in? It should be. It hasn't flipped a breaker off has it?
SOURCE: washing machine wont start on any cylcle,
Dear jwarbonnet,
ngfam at you service!
TRY UNPLUGING IT AND THEN REBOOT IT .IF THIS WORKS THEN YOU ARE SAFE!
OTHERWISE
This sounds like it will only fixed by service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
SOURCE: dE code on WM0642HW TROMM washing machine
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
