Its not the anti flood and the circulation pump is working fine it fills very high and then drains and the wash pump doesnt kick in at all
SOURCE: indesit dishwasher DV62
You have a blockage in your drain pump. Remove all filters and scoop out as much water as you can from the unit. Check in the bottom for any objects stuck there. Some models have a cover on the bottom inside the unit, which once removed, will expose the drain pump impeller. If yours does, remove the cover(usually 1 screw only) and free the drain pump impeller. NB: DO NOT REMOVE THE SCREWS WHICH HOLD THE BASE TUB IN PLACE! These are the screws on the edge of the white plastic "bowl" inside the unit. The drain pump cover will be INSIDE this bowl and will be quite small, no more than 5cm dia.... If this does not work, you will have to remove the drain pump from the bottom or front of the unit to get the blockage out. Oshie
SOURCE: Indesit DV620
check your manual it should tell you what this code means and wether you can deal with it yourself
SOURCE: Indesit Standard WIL 123 (UK) Washing Machine
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
SOURCE: Indesit D167. When cycle selected no water pumping or filling but 1 & 2 green indicators on.
Tilt your dishwasher forwards. Be aware that water will come out ouf the bottom. Once this is clear your washer should be Ok.
Good Luck
SOURCE: indesit idl 705
if the pump is not humming or is humming but not pumping i would replace it.
Hi
Intake/Drain light flashing means an issue while
draining. You would need to check for air gap on the dishwasher, it may be
clogged. It prevents dishwasher from draining, sometimes the drain flow is
restricted due to gunk. Cleaning or bypassing the air gap will resolve the
issue. If this doesn't resolve the issue then it is due to seized (or stuck)
drain pump. Disconnect the power to the dishwasher or turn off the breaker to
the dishwasher. Tip machine on its back; remove screws that hold the bottom tray
on. Remove the hoses to the main motor, remove electrical connections &
remove motor (single screw holds motor, it is on the outside back of the
machine). Try to rotate the motor (use WD40 is necessary). If you cannot rotate
it, then motor will be required. If the error still appears then cancel the
error message, turn the rotary selector switch to "Stop/End" or press
the "Start/Stop" switch for approx. 5 secs. Switch the appliance off
and then back on again. Hope this helps... Please post back if you need more
information.
Daniel
