Question about Zebra Z4Mplus Label Printer
My zebra z4mplus printer loads all the labels on the roll and when load the labels in the printer and turn the machine on. How can I make the printer stop loading after one label comes out?
    Habit-Forming:
    Scholar:
  • 51 Answers
I think your printer is set to print on Continuos media. If you use gap labels, you will need to set the printer from the menu on NOT CONTINUOS, then save the setting. In some cases the software or driver is the one who controls this setting. So you will need to change directly in the printer driver. You will find this option on the General tab (click Properties then) and Advanced tab (click on Printing Defaults). There you will have a list with printing parameters like speed, darkness, media type. Adjust as you need to fulfill your request. But first change directly to the printer, accessing the menu from control panel.
Posted on Jun 03, 2014
3 Suggested Answers
6ya staff
SOURCE:
Jim MacKenzie
  • 15 Answers
SOURCE: Stripe S600 Thermal Label Printer: how to load zebra stripe printer labels...
CLICK HERE to download the full user manual from Zebra. If the link doesn't work, go to Zebra.com, click Resource Library at the top of the screen, then click MANUAL. Choose your model number then follow the prompts.
Posted on Jun 07, 2010
codabar
Raza Codabar
  • 4 Answers
SOURCE: zEBRA z4MPLUS LABEL PRINTER
Do Media and Ribbon Calibration . in printer parameters
Posted on Jul 07, 2010
Calibration
I think your printer is set to print on Continuos media. If you use gap labels, you will need to set the printer from the menu on NOT CONTINUOS, then save the setting. In some cases the software or driver is the one who controls this setting. So you will need to change directly in the printer driver. You will find this option on the General tab (click Properties then) and Advanced tab (click on Printing Defaults). There you will have a list with printing parameters like speed, darkness, media type. Adjust as you need to fulfill your request. But first change directly to the printer, accessing the menu from control panel. Also verify if there is no label sticked on the media gap sensor.
May 08, 2014 | Zebra Z4Mplus Label Printer
My label starts printing halfway down the label
hi,
1. Check the printer settings of the software you are printing with.[most
probable cause]
cause]]
2. Turn off printer.
Open the printer and remove the labels roll.Re-load it and close the printer.
Press and hold the feed button.
Power on the printer and release button after first flash of led light.
Printer will self test.
Turn it off and on again.
Now print.
good luck!
Sep 09, 2011 | Zebra Z4Mplus Label Printer
Labels feeding incorrectly on Z4Mplus Zebra priner
Use this link and download the quick setup guide. Page 4 shows how to properly load the labels.
http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
Aug 10, 2010 | Zebra Z4Mplus Label Printer
ZEBRA z4MPLUS LABEL PRINTER
Jun 29, 2010 | Zebra Z4Mplus Label Printer
My machine keeps reading
Sounds like you may have inadvertenly loaded the ribbon underneath the label sensor, blocking it, and making the printer think it's out of labels. Check the ribbon path to make sure it's loaded above the label sensor.
Hope that helps !
Apr 27, 2010 | Zebra Z4Mplus Label Printer
Why does the label wrap around the bar every other label I print?
Try a different roll of labels. Clean with 100% alcahol
Apr 06, 2010 | Zebra Z4Mplus Label Printer
My Zebra Z4Mplus printer is skipping labels when I print
check the label margins, and label dimensions, and spacing , normaly is these problem, or is a printer driver problem, try reinstall driver
Jan 13, 2010 | Zebra Z4Mplus Label Printer
Change label size
Turn the power off. Remove old stock. Load new stock. Turn power on. Restart your program. Form size is software controlled from your form settings downloaded into the printer before your print. Make sure you restart your software to reload them.
Sep 03, 2008 | Zebra Z4Mplus Label Printer
Zebra Z4MPlus Ribbon Wrinkles
I changed the print head, and the issue was solved.
Aug 01, 2008 | Zebra Z4Mplus Label Printer
Zebra Z4Mplus Label Printer Logo
94 people viewed this question
Top Zebra Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marvin
Marvin
Ekse
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
