SOURCE: need photo of routing blade belt for 42
I'm sending you a link for you to obtain a users manual for your mower.
To get the correct manual, you will need your Model Number and Serial Number... the website of the link will tell you how to obtain those from your mower.
The manual would be good to have, anyway and should illustrate the correct belt routing and many other specifics.
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10451
Hope this helps... Good luck!
SOURCE: mtd 22" yard machine staryts and dies using prospray.
Remove the float bowl again and remove the BRASS Jet in the bottom of the venturi throat. Clean the pin hole of the Jet so that you can see through it. DO NOT force anything through it. Just clean it. Underneath the jet is the venturi tube itself. It is also unscrewed with a screw driver. Remove it and clean all ofthe holes in it. Then reassemble tube and jet in to the venturi. Check the BOWL NUT for 2 holes. If the holes are clogged your engine will suffer from a lack of fuel. Lastly check that you have FUEL flow from the tank to the carb. If the tank outlet hole is clogged you will also have a lack of fuel problem.
Testimonial: "Thank you for your very helpful advice and detailed insructions as to what to do to correct this problem with starting my mower. runs like new now. Thanks again for taking the time to help me out. Grump."
SOURCE: What kind of oil shoukd I use on a 24"cut MTD yard
I'm assuming you have a Tecumseh engine on there. But a Briggs would be the same. This is straight from Tecumseh, though (long story short is run 5W30 Oil or 0W30 Synthetic in it assuming winter temperatures:
SOURCE: where is the prime button on a yard machine 139cc 21' cut
Just below the air filter housing.
