Question about Dell OPTIPLEX 745 PC Desktop
Headphone jack is broken INSIDE the port and is overriding the speakers. Can I override this override?
The headphones' jack broke off but is crammed into the front panel port and now I can't remove it to let the speakers (connected to the back panel) play. Is there a way to adjust my settings to have the earphones' front connector ignored?
    New Friend:
Or instead of having to open up your computer and messing with the mobo. Just use the control panel in to disable the headphone jack.
Posted on Nov 19, 2014
  • Daniel Englard
    Daniel Englard Jan 21, 2016
    How do i disable the headphone jack using control panel i have same problem?
  • tim brauer
    tim brauer Jan 26, 2016
    this may help you outhttps://www.youtube.com/watch?v=czWcj_bX...
    process is much the same in win 8 and win 10
    Habit-Forming:
  • 69 Answers
The front audio connector wire can be disconnected from the motherboard. Both the front speaker jack and microphone jack will be disabled by doing this.
3 Suggested Answers
Anonymous
SOURCE:
Anonymous
SOURCE: Broken headphone jack
you should be able to get it out from the inside on the card. Do you have a sound card or is your sound on the motherboard?
Posted on Jan 30, 2009
TechyDrood
Justin
  • 2072 Answers
SOURCE: headphone jack has a piece of connector stuck in it and it is making my speakers not work how can i fix this problem?
You will need to remove the broken piece. Power down the computer and unplug it. The only suggestion I would have is see if you get get to the jack from inside the computer and push out the broken piece with a paper clip.
Posted on Jun 12, 2012
Why don't I have any sound coming from the speakers in the monitor? the headset jack works in the front. do i have to have a separate cable from the back hooked into the monitor
Yes. The monitor most likely connected via a VGA port and cable, which does not carry sound. Only exception to this is if your monitor is connected to an HDMI port, which carries video and sound. Your VGA monitor should have an audio input port and you should have an audio out jack in rear of the PC; sometimes on the front, not to be confused with headphone jack. A monitor speaker will not work with headphones plugged in, like most receivers. Good luck
Mar 01, 2018 | The Computers & Internet
Front 4 usb ports and microphone and headphone jacks don't work but the rear usb and speaker jacks do work. I've had the computer new since 2009 and they have never worked.
it sounds to me like the wires from the front panel connectors are not connected to the motherboard inside the computer case, open the case up find the front connectors wires inside and find out if there are any connectors on the motherboard to plug them into.
the reason the rear ones work is because they are soldered directly to the motherboard.
good luck.
Jun 28, 2014 | Acer Aspire E380 ASE380-UD500A PC Desktop
My speaker jack broke off inside my audio input in the back of the computer. I want to use the thermaltake case's front usb and audio out/mic in jacks, but they don't seem to get power or work. My drivers...
> Have you removed the broken jack from the rear end of the pc ?
> Are you trying to use the audio ports on the front panel ?
> if you are trying to use the audio port on the front panel you will first need to remove the piece of the broken jack stuck in the rear port - cos you can take an audio out line either from the front OR the rear any one
Oct 22, 2013 | Thermaltake Mid-Tower VL10001W2Z Element G...
I cant get sound on my viewsonic va520
You need to add some information - what is the source for the video that you are viewing on the VA520? The VA520 has no speakers in it. If it is a desktop computer, look on the back of the computer for a green 3.5 mm stereo audio port. This is your speaker out connection. Plug in any set of computer speakers or headphones. (Computer speakers may require a USB connection or to be plugged into an AC outlet to power the speakers.) You can find cheap speakers for under $20; good speakers will be more expensive. With a laptop or some desktops, you'll find a headphone jack on the front of the computer. (This will be labeled with a small picture of a set of headphones.) The headphone jack is also a 3.5 mm stereo port.
I hope this helps.
(laptops usually have internal speakers; most desktops do not have any internal speaker anymore. If you have headphones with RCA audio plugs, you can use a RCA F/F to 3.5 mm M audio adapter to use them with the computer. A stereo system may not work with a computer.)
Jul 24, 2012 | ViewSonic VA520 15" Flat Panel LCD Monitor
No sound from headphones. Speakers work. Win7
Please clarify, Where is the Headphones connected? Front or back? if you tried it on the Front port without success, Plug in the speaker jack to the port where you did connect the Headphone and verify it's working or not. You can also try the headphone on the port where the speaker is connected.
Awaiting.
Nov 03, 2010 | HP Pavilion m7480n (882780389410) PC...
I need to dismantle the HP IQ770 to get at the 3.5mm headphone socket on the front - I have opened the casing and can remove power supply, HDD and DVD Drive but no obvious way to get any further without...
I too needed to get to the jack. We broke the tip off inside. I could not get to the jack, but I did find the plug for the front jack on the board. Unplugged it and the speakers worked fine, and the headphone worked off of the rear speaker jack (green).
Jun 24, 2009 | HP TouchSmart IQ770 PC Desktop
Can't get headphone jack on front of computer to work
The headphone jack up front may not be connected to the PC's integrated audio on the motherboard (or to the PC's sound card if you purchased one with the system instead. There'll be an audio cable running from the front of the computer to a port on the motherboard. If you look at this motherboard diagram for the Vostro 220 (not the 420 or 220s), it'll be the port numbered "15" that's the opne for the audio for the front panel. You don't need the speakers plugged on the back to have the headphones work, but having them plugged in will at least tell you if the sound is working or not.
Mar 27, 2009 | Dell Vostro 220 Desktop Computer
Headphone jack broke off inside
yes, you could easily open the computer and physically remove the wires from the mother board for the front audio jack. These are pin headers. Most all the time they are labeled.
The rear audio should already be working from the green jack. If not, then perhaps you have the RealTek Audio chipset and software. The realtek audio software generally has a orange speaker icon in the system tray. You can double click to open it, go to the Audio I/O tab and then click the little wrench icon. It will open the connector setting. On the connector settings screen is a checkbox. Disable front panel jack detection. Uncheck that, also a check box for Mute rear panel output when fron headphone plugged in, UNCHECK this. That should do it.
If you want to try further to remove the broken jack make sure the machine is off, use a very tiny needle nose pliers (electronic type) you should be able to pull it out.
What kind of computer do you have? You could also possibly remove the jack assembly from the inside, so you can get a better view for the extraction of the plug.
b
Dec 13, 2008 | E-Machines T2898 (764296109563) PC Desktop
Soundcard problem on D530 SFF
Sounds like the audio return wires aren't connected. On the motherboard, there is a sound jack on the back left side of the mobo. The jacks from the front audio panel connects to it. Both the Left and Right channel have an out and an in connector. These send the signal to the headphone jack on the front panel and return the signal to the rear output jack if a headphone is not connected. Look for looe or broken wires. The other spot to check is the front headphone jack. If a headphone plug was pulled out or pulled sideways, it could break the solder joint on the PCB panel or break the shunt feeding the singal to the rear jacks. Hope this helps.
Ron
Apr 13, 2008 | HP Compaq Business d530 PC Desktop
Headphone jack not working.
If you have a headphone jack at the front and the back, it may be a wire to the front panel is not connected properly on the Motherboard.
Aug 03, 2007 | RaidMax Samurai 908 Yellow Mid Tower ATX...
Dell OPTIPLEX 745 PC Desktop Logo
272 people viewed this question
Ekse
Thomas F. Schneider
