Question about Lexmark X6650 4-In-One Wireless InkJet Printer
I changed routers and the printer will no longer connect
  • 523 Answers
Its very simple the Ip addresses changed. check the ip address of the machine, could be the Dhcp was on and it change the ip address so no longer u can print.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Posted on Jun 23, 2009
I use to have netgear16 for my wireless I returned it and got a verizon wireless router and I can't get my printer to print it keeps telling me I'm offline and I think it's because it's still connecte
Not quite sure we got the complete message there- but here goes., You've recently changed routers and now your networked printer is no longer connecting to the network.
1.) remove the driver from your Pc
2.) turn on printer- when ready press menu button , use the arrow keys to navigate and the print switch for enter - select SETUP, then I/O connections/networking, then select Auto-IP enabled, Boot DHCP.
3.) turn off the printer, wait 10 seconds, turn on the printer allow to come to ready
4.)n reinstall the driver, it should search automatically for the printer.
Mar 06, 2014 | HP PhotoSmart Office Equipment & Supplies
Lost my network printer connection
creating the network again would probably solve the issue with it because now you are changing up the hardware for the router. so you will have to set the permissons on the router and the permisons on the comuter to allow the connection to the printer the print share network.
looks to me you have the awnser to your own issue, if you list the router model and what operating system you are running I can give you a more indepth break down.
Aug 06, 2008 | HP OfficeJet 7410 All-In-One InkJet...
My laptop will no longer print via my router connected to my desktop. Please advise how to reconnect.
can the laptop get on the internet? that tells me you're still connected to the router. how is your printer connected? through the router directly (or wireless) or do you share the printer from your desktop (your desktop must stay on in order to print from the laptop.
May 03, 2011 | Computers & Internet
1. The printer is printing everything in landscape. I have checked the settings and it is set to portrait printing. I tried changing it to landscape and then back and it still printed in landscape. ...
1. You could try to reinstall the Z2420 driver on your computer. 2. Try to reset the wireless network adapter of your printer. Follow the instructions in this article from the Lexmark website on How to Reset the Internal Network Adapter on Lexmark Z2400 Series Printers. Open Lexmark Wireless Setup Utility to reconfigure your printer to connect to your wireless network.
Thanks.
Feb 24, 2011 | Lexmark Z2420 Printer
I have changed my router and my networked printer no longer works
Hello Warren !
What happened is that when you replace the router, the IP Address for your printer changed as well. Your network printer connects to your computer through a number called the "IP address" wich is assigned by your router, since you replace your router, the new router assign a new Ip address for the printer, so you will need to change that IP address on the printer driver on your computer as well.
What you need to do is print a configuration report directly from the printer to figure out what the new IP.
When you have this number ( it will look something like "192.168.0.1")
you need to go to "printer and faxes" under control panel, make a right click on the MFC-465 icon, go to properties, then go to the ports tab a click on "Add Port" select Standard TCP/IP and type in the new ip address.
This should reentablish the communication between your printer and computer.
Good Luck
You can contact me directly here:
eliteprintersolutions@gmail.com
Jul 15, 2010 | Brother MFC-465CN InkJet Printer
SECUTITY TO STOP OTHER PEOPLE USING MY WIRLESS INTERNET
I connected to my Belkin G Plus MIMO router using IP address 192.168.2.1 to enable security to prevent others connecting to my system. I enabled password just to start with. I also changed Time to GMT time and I changed someting about Server to European (I forget what exactly it was). The result was when I confirmed these changes my router will no longer respond to this IP address and no longer works for me. How can I get connected again to change timngs !
Sep 12, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
The wireless adapter on my pc is now longer working
Do you still have this problem? If so, please be more specific.
What do you mean, the pc can detect the network (router) but I can no longer connect to the router. ?
May 18, 2008 | Intel Computers & Internet
Lexmark X6650 4-In-One Wireless InkJet Printer Logo
150 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
