I took out and replaced the battery, powered down the phone, checked on settings
You have to change your speaeker located in top of your mobile , maybe is burned out and when you make and receive call there is not sound at all leting your mobile go to speaker loud who is located bottom of your phone, in some cases a new software maybe fix this situation , samme release but you have to do it from begining.
Testimonial: "Not sure I understand. The phone is going to speaker, and it works fine, instead of to normal mode. After I answer I can switch it back to normal, which them also works fine."
you are using your phone with earphone or without it
if this is the case try another pair
if you use your phone in normal mode without earphone a explained before
your phone have two pieces for puting sound out one is in bottom of your phone ,and this is served for loud sound out and one in top which is soft sound till you can put your ear hearing there
if this is blowned out your device remain only with one sound exit which is in bottom the loud one soo all is comming in this way and not in "normal" way for listening in your ear
somme times reflashing your phone software remedy situation but most of the times they not so you have te change a top speaker in your phone
SOURCE: lg vx8100 error message on screen: use genuine battery. power off 10 sec cuts off
I took out the battery on a lg verizon phone oops put it back in now black nothing ?? There must be some sort of way to replace the battery that reinitializes it any help
SOURCE: how do i resolve the error: use genuine battery. power off
A temporary fix to the problem is to put the battery in the freezer for a minute and then put it back in the phone and it will turn on just fine! I had an LGVX8700 and it just randomly started happening one day and my fiance told me to try doing that so i did and sure enough it worked. I had to go to verizon at one point to get a new phone because the one i had got damaged and the tech there used the same battery in my phone for the new one and he thought i was crazy when i told him to put the battery in the freezer but he was in for a surprise when he did what i told him and my phone turned on. It's annoying because you have to do that everytime your phone shuts off but i always made sure i plugged it into the charger before it went completely dead.
SOURCE: Cannot hear calls and call recipients can not hear
you can try a master reset which you can get on att.com/wireless or call att
SOURCE: Need manual for huawei pillar
GO TO HUAWEI SITE AND UNDER SUPPORT CHECK FOR YOUR DEVICE AND OPEN IT AND DOWNLOAD THE MANUAL....
