Question about Sony KDF-E60A20 60 in. LCD HDTV
Where can i get the bulb and what is it called
Kitchenaid frigerator light bulb shield will not move back. Need to change bulb.
According to Kitchenaid, those lights are LEDs and should never need changing.
call for assistance
or service. In the U.S.A., call
1-800-422-1230. In Canada call
1-800-807-6777.
Apr 24, 2017 | KitchenAid Refrigerators
Hid bulb
its called the ballast module that is at fault, it generates the very high voltage to fire the hid bulb or burner as it is called, may be part of the headlamp unit, check with your jag dealer. not cheap i dont think
Jun 08, 2013 | 2003 Jaguar X-Type
What is the tag light called?not the bulb but the piece you put the bulb in.on a 1977 dodge truck
The whole thing is called the 'license plate light assembly', the part the bulb actually goes in is the 'bulb socket'.
Hope this helps!
Feb 23, 2010 | 2005 Toyota Camry Solara
07 max headlight, what is that piece called that locks the bulb in place?
In the Nissan service manual it is called the "Headlamp Bulb Plastic Cap". This part covers the bulb. Then you twist the bulb socket to remove the bulb.
Jul 29, 2009 | 2007 Nissan Maxima 3.5 Sl Sedan
Miele DA270 Vent Hood Light Bulbs
I just bought two at Home Depot for around $7 each. I, too, saw the inexpensive internet ones and decided to spend the extra money and look at them first. I bought bulbs by Philips, called Desk & Cabinet (for enclosed bulbs). They are 20W and 12 volts as you said. It's a G4 Base T3. Now that I have these, I'll likely buy the cheaper ones next time.
Mar 24, 2009 | Miele 90cm Decorator Island Hood - Vented...
Need replacement bulbs for 21.6V Kawasaki Tools Flash Light
I called customer service and they said that you have to use a Craftsman brand 19.2 volt replacement bulb and it will work.
Mar 11, 2009 | RTO 21.6v Kawasaki 4 Piece Cordless Power...
Can't change light bulb
yes you wilkl need to remov ethe micro from the oven mountingin order to access the light bulb (dumb-design) but no way around it
Nov 16, 2008 | KitchenAid Architect Series KEMC308KSS...
Does a LCD TV have a light bulb in them? If so, how long should it last?
There are 2 kind of LCD vision, one have Bulb (its bit older ersion) and 2nd LCD have Back-Light for illumination. LCD with Bulb calls "LCD Projection" and back-light LCD calls "LCD TV".
If you need further info, please post back here.
Aug 19, 2008 | Televison & Video
No picture, just sound, everything is plugged in correctly.
I have the KDFE42A10 and it is two years old I started having the same problem as you. I would turn on the TV and after the minute of blinking green LED I would get sound and no video. It started out taking 5 minutes to come on and is now up to about 30 minutes. I did call for service and the first people scratched their head and said it must be the bulb. So since the bulb wasn't covered I had to buy that ($200), I put it in and no go so I called for service again and said don't send the same people again. This time when he came he said right away it's not the bulb and never was and he called Sony since he had no idea and their suggestion was the B Block so it's now on order and should be in a couple weeks. After the first person came to service it and said it was the bulb I called sony second level help and they said it wasn't the bulb and if it was I the first person to have this problem and be the bulb. They told me to call Sony service back and tell them to have another company come and service it since the first one diagnosed it incorrect. So I did and Sony service told me they the people that they have service for them are highly qualified and they would not send another service call on it until I replaced the $200 bulb. The told me if I wanted to pay to have it service by someone else that was up to me but as far as they were concerned they serviced it and determined it was the bulb (which it wasn't) I would never buy another Sony product after this deal. On another note the last two service calls only took about two weeks to get some one out on it. The speed of Sony service is very slow.
Feb 23, 2008 | Televison & Video
Sony KDF-E60A20 60 in. LCD HDTV Logo
24 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
