Question about LG WM0642H Front Load
My LG will not start - lights come on, door locks then it has a faint humming sound
Earlier in the week, I noticed that it was humming during the spin cycle. Now nothing.
5 Suggested Answers
Anonymous
SOURCE: LG WM1814CW Front load washer PF continues to come on and stops cycle
Seen This before Main control board fixed it It would go through most of the wash cycle and just quit no errors but PF
Posted on Jan 29, 2008
Anonymous
  • 373 Answers
SOURCE: vibration during spin cycle
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Posted on Dec 13, 2008
Anonymous
SOURCE: "le" on the LG WM0532hw front load washer errror
try unpluging for 45 seconds than hold in the selector knob for 10 sec. & plug back in
Posted on May 18, 2009
pappapumpdaf
Bob Sloan
  • 635 Answers
SOURCE: LG Tromm wm 1814cw makes loud noise
You will need to remove the back cover plate of the machine and locate the large pulley at the end of the drum. Remove the belt, then the pulley and you should see a bearing housing. Some models require a bearing and housing replacement, while others can simply be repaired with a bearing replacement alone.
Go here, and find the nearest Dealer for your part.
http://www.1stsourceparts.com/contact_us/branch_info.asp
Or you can try ordering direct from LG. If you are as handy with tools as you say, this should be a fairly easy job.
Posted on Mar 23, 2010
Duet dryer is making a humming noise when cycle starts a d during
whenever i hear a humming sound in a dryer it's usually the motor or something caught in the blower wheel stopping the motor from spinning.open the door and see if you can spin the drum.if it spins by hand try this,open the door,push in the door switch with one hand,have someone push the start button while you hold in the door switch and spin the drum by hand helping it move,if it runs you have a bad motor,if it doesn't remove the bottom panel and see if the belt is broke and stuck in the motor but like i say usually it has something to do with the motor not spinning.hope this helps
Oct 21, 2013 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
My 1996 plymouth voyager started to show short when I open either door. Heard clicking earlier when used left tyrn signal. Sounds seems to come from below junction block but I cannot see sparks or wor
There is a wiring harness that feeds to the door, electric door locks and windows draw a lot of amperage. Try removing fuses one at a time that supply power to your door controls until you see the problem go away. If that doesn't work, try other fuses to accessories like interior lights. If your headlights are dimming you have a power wire shorting to another circuit, if it were to ground it would blow a fuse.
Apr 30, 2017 | 1996 Plymouth Voyager
LG Tromm WM2277HW
Does spin only work well?
Apr 11, 2017 | LG WM-2277HW Front Load Washer
It made a quite hum during the spin cycle, instead of the normal (much louder) spinning sound. When I turned it off I noticed it had a rubber/electric burning smell.
If it's a squealing sound, your belt is probably bad. If it's a humming noise with those smells you listed, it might be your transmission going bad.
Nov 02, 2009 | GE WBSE2090A Top Load Washer
Humming, but no spinning
It could be the capacitor which kick starts the motor.
they are relatively cheap to replace.
Ash
Oct 22, 2009 | Frigidaire Dryers
LG LFX25960SW Refrigerator--Display goes bizerk
It is going thru a diagnostic process, But this is only to happen when you either open the circuit board and press the test button, or use the front display keypads. I would have the circuit board checked
Jul 27, 2009 | LG LFX25960ST Stainless Steel French Door...
92 Ford Taurus Won't Start
The hum you hear is the fuel pump. I would start with the battery and have it load tested, then I would pull the starter and have it tested.
Jun 21, 2009 | 1992 Ford Taurus
The washer just stopped pouring water. Only faint humming sound.
Cool!
How 'bout a FixYa for the effort, and let me know if you need anything else.
Feb 04, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Beko 520w wasing machine
Hi see the last video on this it will show you test mode or if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Mar 08, 2008 | Washing Machines
Buzzes will not spin
Plug off the wall, check behind for the belt may have come off.
Dec 16, 2007 | Frigidaire GLTR1670A Front Load Washer
LG WM0642H Front Load Logo
42 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
