SOURCE: The flash isn't working
might be obvious, but try replacing the batteries. also during continuous shot mode, flash will be automatically set to off. otherwise contact samsung for repair estimate. Good luck
SOURCE: Samsung S730 No Flash
If you don’t find a solution you may want to try [email protected]. He was able to give me some great advice and he has used parts in good condition and at a good price. It worked for me.
SOURCE: problem on outdoor daylight picture taking
hi
try the Exposure button [+/-] will generally be disabled in auto mode
try changing mode to 'P' (Program) mode and then change the exposure by pressing the +/- button and then you would generally see a scale on the LCD now press the left button to decrease the exposure
better more is to reset the camera to the default settings this would set the aperture, shutter, Exposure, LCD brightness and otehr settings to defaults and this would save from any unwanted changes than required
cheers
pls rate if it was any help
SOURCE: My camera seems to short out and there are horizontal lines in the pictures.
get new batteries, if recharging your current batteries does not work (to stop it shorting out).
reduce your shutter exposure, by changing to Manual Mode (M), selecting +/-, and then the left button (flash) around the Menu OK button. Mine works fine at 1s shutter speed, but was showing horizontal lines before that ...
SOURCE: Help me if you can, ASAP. Please.
The flashing eye has to do with the camera's red-eye reduction feature. Check to see that the little window below the flash on the front of the camera is clean, and make sure the lens is spotless. If that doesn't work, try de-activating the red-eye reduction using the camera menu.
check for dust specks on the lens glass.
