I need the solution please
Usually these are just software issues which can be solved by uninstalling the old one and reinstalling it. Cleaning the system with a cleaning utility of all old unwanted files, links etc may help solve the issue. Restoring your system to an earlier date when you didnot have any issues will also solve the problem. Especially in Windows Xp.
SOURCE: i have kyocera km 1650
press status key
scroll down to service
press enter
press 163
press enter
wait 10 seconds
recycle power
SOURCE: Kyocera KM-2050 Problem error C6400
Fuser unit Error code, you can try to reset, but if the code still there, you need to change the fuser unit.
This is the way to reset your fuser code;
On the panel press 1087 1087
this will take you to the service mode,(look into the screen)
now on the panel again press 163 and hit the start key.
Look in the screen, you will see execute, select execute by the arrow and hit the start key, the machine will turn off then on. or it will ask you to turn the main power off than on. this might fix your problem, if not! change the fuser.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
c4000 polygon motor sychronize error, try to cleaning polygon, if not effective, need to replace new polygon.
Testimonial: "thanks it help alot"
