My ah59 02291a remote wont connect to my toshiba tv or to my samsung HT-C450 it has batteries in and everything i have no clue what to do?
SOURCE: Samsung HT-Q100 - Changed Battery on TV remote control
Just try to clean your remote,this the common problem of dirty contacts of remote it plays a certain unit but to the other won't play.Just open it take a toothbrush with an alcohol brush the remote control board,and dry it for 1minute and close it back then check if working..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
SOURCE: sony c450 will not work with new 46" Samsung TV using compodent 3
are you sure that the channel your tv is on matches the name on the inputs where you plugged the component cables in? Channel surf-maybe start at 2 and go down and that is where those input channels should be.
SOURCE: Insignia Remote Code Needed for Samsung HT-X40
Many remote control codes can be found at InsigniaProducts.com. Search for your Insignia product model number and click on the Support tab.
SOURCE: samsung LED UE46B7020 tv wont play sound through my HT-C5500
press the top right hand button on the remote for the ht-c5500 untill its display reads "D.IN" (Digital Input)
SOURCE: Need Vizio TV code for my Samsung HT-X50 home theater remote!
Mine is 5. Press the TV button and let it go. When it quits glowing press the power button and hold it down. Then press a number (1-86) on the keypad while holding the power button down. If the TV turns off, you are done. Press the power button again and the tv should come on. If it does not work. Release the power button for a second and then repeat with a different number until the tv turns off.
