Question about LG WM2688H Front Load Washer
What does cl mean - LG WM2688H Front Load Washer
I have a Canon Pixma MG printer . There's orange lights at BK & CL that are blinking? What does that mean ?
means that the toner cartridges are just about out of ink and need replacing
BK=black and CL= color
Mar 15, 2016 | Canon Office Equipment & Supplies
My display is alternating between CL and and won't take messages. What should I do.
CL means that the clock is not set and when that is the case, the answering machine wont work.
Oct 03, 2015 | Vtech 5.8GHz Cordless Phone with Digital...
On an LG front loading washing machine, what does the code CL mean?
Hi Emma Haigh,
CL means Child Lock, please follow my below Tip on how to remove the setting:
L.G CL ERROR/CODE
Kind Regards
JEDMEYER1
* If you found this solution helpful, please rate it
Aug 01, 2011 | LG Washing Machines
Flashing CL?
A flashing CL means that you have to set the clock.
Nov 11, 2009 | Lands Phones
The washing machine doesnt start at all. The displayer says: CL.
CL means "means chils lock" to disengage hold temp and echo/rapid together and this should solve the problem
Jun 21, 2009 | LG Washing Machines
CL code
I'm getting CL too, and don't know what that means, but I DO know how to get your remote phones to work. Before I lost the manual I had to do that. Simply set each one in the main charger for about 20 seconds and they will work.
Mar 15, 2009 | GE Lands Phones
Lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
Jan 29, 2009 | LG WM-2277HW Front Load Washer
LG WM1285 WASHING MACHINE
hi Hills659.
this is all i could find out.
What does CL mean on LG washing machine?
LG Washer CL Code Definition (What does it mean?) = The CL Code on front loading LG washing machines simply means the CHILD LOCK feature is turned ON.
The CHILD LOCK feature on your LG washer is meant as a safety precaution so children are not able to change wash settings. CL is not an error code. It is indicating that the CL or CHILD LOCK feature has been turned ON and is active.
LG Washer Error Code CL How To Turn CHILD LOCK Off
Dec 17, 2017 | LG Washing Machines
Error Message CL in the front panel
Error message CL solved. CL means child lock. To deactivate press two linked buttons (on my machine the right options button and the temp button) together for a couple of seconds.
Mar 29, 2008 | LG WM-12230FB Front Load Washer
LG WM2688H Front Load Washer Logo
46 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
