What should I do if my TV screen turned black, blue, or gray?
Print
try this.
Proceed with the troubleshooting steps below only if you're seeing:
Note: If your TV screen appears "frozen" or you're seeing wavy lines or overlapping images, try this.
Solution 1: Check that your TV is set on the right input
[img border="0" alt="Image" src="https://cdns.directv.com/cms2/global/icons/sm_cl_blu__number1_icon.png">Turn your TV and receiver off and back on.
[img border="0" alt="Image" src="https://cdns.directv.com/cms2/global/icons/sm_cl_blu__number2_icon.png">Using your DIRECTV remote control, press the TV Input button to cycle through TV inputs (Component, HDMI, etc) until you see a picture. If nothing happens when you press the button, try programming your DIRECTV remote to control your TV Input and try again.
Note: You can also try changing the TV Input using your TV remote.
[img border="0" alt="Image" src="http://www.directv.com/cms2/global/icons/sm_cl_blu__number3_icon.png">If you're still having issues, check the cable used to connect your receiver to your TV.
Still not seeing a clear picture?
Continue to Solution 2.
[img border="0" alt="Image" src="https://cdns.directv.com/cms2/support/answer_center/tech_faq_images/img_screen_off_4.jpg">
Solution 2: Reset Your Receiver
[img border="0" alt="Image" src="https://cdns.directv.com/cms2/global/icons/sm_cl_blu__number1_icon.png">On some DIRECTV receivers there is a red reset button located inside the access card door on the front panel. Press it, then wait for your receiver to reboot.
Note: If you cannot locate the red reset button or your receiver does not have one, unplug the receiver's power cord from the electrical outlet, wait 15 seconds, and plug it back in. Then press the Power button on the front panel of your receiver and wait for your receiver to reboot.
Hold the on/off button in while TV is off for 30 seconds and then try it!
