Watches Logo
zaraa Posted on May 13, 2014
Could you help me with my roxy crushin krw222dr watch ? i cant set the time and date . please ?
Carolyn Danhardt
Level 1:
New Friend:
  • Contributor 38 Answers
  • Posted on May 13, 2014
Carolyn Danhardt
Contributor
Level 1:
New Friend:
Answers
38
Questions
0
Helped
12424
Points
68
Click on this link, to view the manual
http://media.quiksilver.com.au/media/rx/watch-manual/RX%20Crushin.pdf http://media.quiksilver.com.au/media/rx/watch-manual/RX%20Crushin.pdf
1 Related Answer
SKW914
  • Posted on Dec 23, 2008
SOURCE: how to set up ladies roxy digital watch
I found users instructions on roxy website at:
http://www.roxy.com/search/index.jsp?f=Taxonomy%2FROXY%2F2818169&categoryId=2818071&f=Taxonomy%2FROXY%2F2818071&fbc=1&fbn=Taxonomy|Watches&fbx=0
We were able to program our watch completely!!!
If you look on the back of the watch that you bought on the metal plate, it tells you the style. Ours was the Roxy 70's digital watch, and I found specific instructions at (even if this is not your style, the instructions may work):
http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf
How to set up roxy crushin watch
how to set the time of my roxy crushing watch
I have a roxy candy watch and I can't figure out how to reset the time. Please help!
Current Roxy watches can be found here:
http://www.roxy.com/family/index.jsp?categoryId=2818071&searchSort=TRUE&pg=1&f=Taxonomy%2FROXY%2F2818071&s=D-ProductAge&fbn=Taxonomy%7CWatches&fbc=1
I don't see a "candy" model but there are some called "Jam".
If one of these is similar to your model, click on the picture of the watch, a new page will open. Under the color choices on the right side you will see a link to the Manual. The manual will have setting instructions.
Apr 03, 2011 • Watches
5helpful
I cant figure out how to set time and date
Hi idarr,
Please follow these steps to set the time and date of your Armitron Digital Sport #40/8125BLK Watch.
1. Press the MODE button once. This will put you in the timer.
2. Press and hold down the MODE button. This will put you in the alarm set display.
3. Press the MODE button once more and it will put you in the time set display.
4. Use the ST/SP button to change the blinking portion of the time. Then use RESET button to move you thru the different parts of the time/date.
Hope it helps.
Thank you for using FixYa.
I cant set the right date on my timex 1440 sports watch
Hi travislietha,
To set the right date on your timex, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
4helpful
I have a Baby g roxy life watch. the number on the
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please.
Roxy 70's watch alarm goes off every hour. I
This manual will help http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf
I think these are the directions you need 2.0 Alarm and Chime On/Off 2.1 In Normal Display hold B-Button,and push A-Button once: Chime will be on. 2.2 push A-Button once again: Alarm will be on 2.3 push A-Button once again: Chime will be off 2.4 push A-Button once again: Alarm will be off 2.5 Release B-Button, the Display changes to Normal Display immediately.
Jul 13, 2009 • Watches
3helpful
Hi, I need help with this brand of Roxy blue Calculator watch insurction and I got them from ebay but she dont have any booklet. I try to set the time. I can't do it so would you make simple explain to me...
Had same problem. Press and hold C (mode) until the display flashes. Then press C again (without releasing) to get to time. Press "Select" to move from sec, min, hours, days, etc. Press advance to go change the actual time.
these directions work http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf if you change the following: C=C Mode A=Select B=Advance
Normal Time Setting 5.1 In Normal Display, hold C-Button for more three seconds and then push C-Button once. Tuesday flag and seconds digits will flash. Push B-Button once to reset the second to zero. 5.2 Push of A-Button once: Minute digits flash and advance by depression of B-Button 5.3 Push of A-Button once again: Hour digits flash and advance as above. 5.4 Push of A-Button once again: Month, digits flash and advance as above 5.5 Push of A-Button once again: Date digits flash and advance as above 5.6 Push of A-Button once again: Flag of weekday flash and advance as above 5.7 If push of C-Button during any changing time, Normal Display will be appeared
Jun 14, 2009 • Watches
12helpful
How to set up ladies roxy digital watch
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
