It print twice when I ask one time... waste a lot of paper
SOURCE: zebra s600
The factory default setting for the S600 is thermal transfer (ribbon). depending on your OS there is a command that can be echoed to the printer to change the setting to direct transfer (non ribbon). It sounds like your printer thinks is should use a ribbon and in fact you are not using a ribbon. Here is the procedure I use to get the ribbon motor to turn on:
1. start with the printer turned off.
2. open the printhead, retract the ribbon completely onto the supply spool. leave the printhead open.
3. Press and hold the top three buttons (PAUSE, FEED and CANCEL) while turning on the printer. When the botom couple lights turn off release the buttons.
4. When you are left with the power light on and the printhead light blinking reinstall the ribbon and close the printhead.
The printer will autoclaibrate and run a sensor test.
Once complete the take up motor should have turned on and you should be able to use thermal transfer labels and a ribbon.
SOURCE: Zebra S4M prints one label then goes to flashing pause light.
most likely it is a printer driver issue. There's 2 drivers, one for 200dpi and one for 300dpi. Use the one for 200dpi. It could also be the label setting is incorrect. Try running a calibration.
SOURCE: zebra s4m error condtion paper out
Sounds like you will need to perform the calibration procedure.
when you access the menu system go to advanced menu, the password is 9999, use the keys to navigate to manual calibration and follow the instructions. when it states load backing this is refering to backing paper, so remove the labels from the backing and place in label path. hope this helps
SOURCE: Zebra S4M Printer doesn't print
The fact that the Data message is displayed, means it is 'seeing' something. You may be losing the command character at the beginning that would cause the machine to ignore the rest of your code. If this is the first time you have attempted to use the serial port, you may have a setting incorrectly set. You need to match your Host exactly or the data may be framed incorrectly. The old standard was to send your data 8 bits, 1 stop-bit and no parity. Try Xon-Xoff with hardware handshaking too. I hope this helps.
SOURCE: How to print to zebra s4m 203dpi using vb6 and usb
You can generate the ZPL code in a text file and send it to a generic printer connected to USB.
Roberto Martinez
