Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
I have to replace the 8 hour defrost timer on my kitchen Aid KBRS22KWMS fridge every 2 or 3 years , is there a defect with these timers or is there a problem with my fridge that causes the defrost t
I have replaced the 8 hour defrost timer model # C646 482493 three times now. When I put the new timer in everything works fine. Within the 2 or 3 years it stops working and the back of the freezer where the fins and heater are gets all iced up. what could cause the timer to break down every 2 or 3 years
    Sergeant:
  • 200 Answers
In a few cases, the timer is getting condensation damage from a poorly sealing door, or a missing shield. Commonly you'll see corrosion or stains on the timer when you remove it which would be a tattletale sign. Check for both when it fails next.
Posted on Jan 09, 2018
6ya staff
SOURCE:
Anonymous
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Posted on Feb 18, 2008
Anonymous
SOURCE: Kitchen Aid Ice Maker will not dispense Ice
Ice will not force the hatch open.
Posted on Jan 22, 2009
Anonymous
  • 9 Answers
SOURCE: Freezer and icemaker freezes, jams.
I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
Posted on May 01, 2009
Joe Hogan
  • 10865 Answers
SOURCE: ice maker in Kitchen Aid stopped making ice
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on May 10, 2009
mgprice
Mike Price
  • 744 Answers
SOURCE: Problem with Kitchen Aid side by Side
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck!
Posted on Jul 11, 2009
My Kitchen Aid Superba refrigerator Model # KSRS25FGWH01 stopped working. no fans come on no noise only fridge lights. working the other day but fridge was not cold enough freezer was fine now nothing
The machine goes into the defrost mode every day or two. During defrost mode you will see these symptoms. After an hour or two, it should return to normal. If not, the defrost timer may be stuck in the defrost position.
Mar 05, 2017 | Refrigerators
Stopped cooling == all lights are on but no cooling in the freezer or fridge sections = has not been used for 2 years
My guess... without the aid of a model number, make or year... is FIRST going to be the power switch is in the "OFF" position.
lights will be on... but nary a fan nor compressor will make any noise (a major compressor failure would NOT be so peaceful).
If it was a similar configuration to my old Amana (SBDE20)
the switch is actually out of sight behind the floor grill
(on the front of the box that contains the Power Board).
THE Other two possibilities...
1. You are stuck in defrost cycle a defective defrost TIMER
2. Stuck defrost cycle due to defective POWER-BOARD.
1 & 2 ARE mutually exclusive... if you have a POWER BOARD... you DO NOT have a defrost timer and vice-versa.
Here's to hoping you spot that power-switch right away.
Good luck.
Dec 07, 2015 | Refrigerators
Kitchen aid ktrs22k
You must have a defective defrost timer.
Jul 22, 2017 | KitchenAid Refrigerators
Ice buildup on evaporator coils
Can you locate the model number of your Kenmore? The number should look like this 521.345678 and located around the inside of the fresh food section door.
It could be that the defrost heater came on the time you were watching bugt may have a bad connection or a defective defrost element. You need to test the heater for continuity to assure that the element is not broken. the defrost timer and defrost thermostat being new eliminates that as being the problem so I think your element or the connection is the most next likely cause, Let me know I don't mind helping, Thanks Sea Breeze
Defrost Heater Testing for Continuity
Jun 23, 2012 | Kenmore 25.1 cu. ft. Side-By-Side...
ON A NEW FRIG, KITCHEN AID KSCS23FVMK, HOW DOES THE DEFROST CYCLE WORK? DOES IT ONLY COME ON WHEN IT NEEDS DEFROSTING OR DOES IT DEFROST EVERY 8 HOURS OR SO BY TIMER IF IT NEEDS IT OR NOT?
It's fully automatic -- it will very briefly kick on the defrost cycle once a day (variable by model) to prevent frost buildup, but not long enough to warm the food.
Sep 26, 2010 | Refrigerators
I have a GE GSS20IEM side by side. It is not
The possibilitty is the 8 hour timer may be defective. This timerr is the one which cut off the compressor and powers the heater to defrost the coooling coils to condense the water to the try below. If this wont happen then the possibility of the cooling coils building up frost will decrease cooling. The thermostat can also be a culprit as the thermostat is also in circuit . You can see if the timer works in this cycle by shutting off the fridge for several hours and restarting to check the defrosting cycle.the timer is placed near to the compressor unit and the heater near the cooling coils. Hope you check this out. Good day .
Jul 26, 2010 | GE GSS20IEM Side by Side Refrigerator
It wont shut off the motor keeps running on my
replace the timer. or the whole kit. defrost timer, defrost terminator, and heater not really expensive. first found the defrost timer. go to the web found a picture. use a screw driver flat turn the timer the midle part. really slow until you hear a click noise. remember really slow. after 2 or 3 min open the frezzer.and listen a sound like the ice breaking. THE ONLY PROBLEM IS THE DEROST TIMER. 35 doll. easy. just be patient. replace the timer. 2 screws. really important. after replace the timer YOU HAVE TO DISCONECT THE FRIDGE AT LEAST 24 HOURS. ALLOW MELTING THE ICE IN THE WHOLE EVAP. REALLY IMPORTANT
Mar 31, 2010 | Refrigerators
Ice building up in fridge
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Jul 12, 2009 | Refrigerators
Ksrs25ikss01 kitchen aid fridge portion not
1.check if the fan inside the freezer is running
2. if ref runs none stop, defrost timer is out.
3. or it could be the high limit that paired in series with the defrost heater
good luck!
Jun 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
GE Monogram Side by Side 42" Freezer light is lit on front panel.
The defrost timer is what I think you are asking. It is behind a cover near the light, The timer puts the fridge in defrost ever 6 to 8 hours. If the timer is bad it will stop the cycle of defrost and cause the freezer and the cold food section to warm spoiling the food and increase the freezer temp. Try turning the timer screw clockwise until you hear the fridge compressor stop. If after this listen for a crackling noise that will be the sound of defrost taking place. If doing this starts defrost, you will need to replace the timer.
Oct 20, 2007 | GE Monogram ZICS360NRRH C... Bottom...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
112 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
geob91
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
