Worked fine. Now wont turn on. Batteries are good.
I just found a solution to my camera problem. It turned out to be the
batteries. We purchases some Rechargable Duracel with a 2650mAh rating.
After charging the batteries I put them in the camera and it started
right up and was taking photos like when we first bought it. I have not
been able to use the camera in almost 2 years and it turns out the
problem was weak batteries.
So anyone that has a Minolta Dimage
7i and cant get it to turn on make sure you have at least 2650mAh rated
rechargable batteries. The higher the mAh rating the better.
Hope this helps someone else. We are ecstatic that we can use our camera again. No more using my camera phone!!!
I dont want to pay you $10. Then you tell me it needs proffesional repair.
I have had the same problem for like 6 months. We had the camera for a little over a year, worked great, took good photos and one day it wouldnt turn on with fully charged batteries.
We put in fully re-charged batteries, turn the power on and all that happens is a blinking battery icon in the top window.
Checked the battery terminals...they look good.
Swapped out the card...didnt work.
Tried 3 different brands of re-chargeable batteries...doesnt make a difference.
We would really like a solution this so we can stop using our grainy camera phones.
Please anyone HELP!
Thank you, Ronnie.
I am using two sets of NiMh Rechargable 2400mAh and 2600mAh.
Still have this problem. It used to work fine and I haven't been using it for a while and than one day this problem happened. When insert 2600-set it starts with flashing batteries signal, and 2600-set is just enough for few minutes. THey used to be OK for almost 3-4 hours shooting before! Don't know what the problem is...
