Runs OK on high setting
YOU PROBABLY HAVE LINKAGE PROBLEMS ON THE CARB IS IT AUTO THROTTLE IF SO YOU MAY ONLY NEED TO ADJUST THE SETTING SCREWS GIVE ME SOME DETAILS LIKE BRAND HORSE POWER CARB BRAND AND MODEL AND I MAY HAVE THE EXACT ANSWER FOR YOU I HAVE ALOT OF SMALL ENGINE RESOURCES FOR SPECS AND DIAGRAMS
1000 watt generator is small power generator. Is it a gasoline generator? Usually, diesel generator power is at least 15KW.
If you want to know about generator tech knowledge, visit this website. Generator Diesel Generator Cummins Generator Volvo Generator Perkins...
The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
