RCA RCU300 Remote Control Logo
Posted on Jun 23, 2009
Need a remote for emerson lcd tv/dvd combo model# ld195em8
5 Related Answers
Gigatech
Rafael Ortiz
  • 259 Answers
  • Posted on Dec 12, 2007
SOURCE: emerson remote for emerson tv/vcr combo
Emerson TV codes 0154, 0236, 0463, 0180, 0178,
0171, 0623
Emerson TV VCR Combos 0479, 1479, 1278
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Anonymous
  • 286 Answers
  • Posted on Dec 29, 2007
SOURCE: remote control code/daenyx tv/dvd combo
Your TV is made by Daewoo and is distributed by Daytek. If you call the 800 number on the warranty card you will reach Daytek.
So, what you need to know is this:
#1. A lot of new products won't have a website available. That does not say anything to their quality or the company, just that you've bought a new product and you're one of the first purchasers.
#2. A lot of times if you buy a "no name" TV, you're actually getting components inside the TV that are made by brand name manufacturers. For example, "Prima" uses LG panels in some of their plasma TVs (as well as Daytek). How do I know this? Because I'm the authorized service provider for Daytek, and Prima and quite a few other "no name" TVs, and I've been working on LCD and Plasma since they came out, as well as having worked in the electronics repair industry for over 20 years. I own an Insignia 42" LCD and am quite happy with it.
#3. Most new products that have remote controls will not have codes available for them no matter what brand of universal remote you buy. You have to wait for the people who make the universal remote to have time to make a code for this new brand of TV. This can take up to a year for cable companies, and cheaper universal remotes may never get the code. Expensive universal remotes may be able to have their firmware updated through the internet, so adoption of new codes for new products may happen faster.
#4. Stores like Walmart and Costco are excellent places to buy products like this because they usually have a "no questions asked" return policy if you get the TV back to the store within the stores time limit for returns (some stores are 15 days, some are 30 days, phone the store and ask them). I had purchased a 40" Digistar LCD TV from Walmart what had a flickering problem, I took it back the next day without any problem at all. Then I bought a 42" Insignia Plasma TV from Future Shop that I wasn't happy with. I took it back 3 days later and had no problem at all. As long as you know the stores policy for returns and follow the policy, you won't have any problems either.
#5. Try to avoid buying big-ticket items from smaller stores unless you know their return policies. Some smaller stores will not accept returns on LCD monitors, TVs or plasma TVs but instead require you to handle any problems through the manufacturer.
#6. Best bet it to call Daytek and ask them if they know of any universal remotes that work on that particular model.
Anonymous
  • 4 Answers
  • Posted on Dec 31, 2007
SOURCE: Need code for Emerson TV,DVD,VCR Combo
I don't have a code book for you, but I can tell you how to program the RCR660 using the automatic programming feature.
Programming RCA model RCR660 (no code search button)
While following these instructions, keep the following in mind:
device = the component you wish to control with your remote (TV, DVD, VCR, etc.)
DEVICE = the button labeled for the component you wish to program
1. Turn on the device you wish to program.
2. Turn off all other devices in the general vicinity.
2. Press and hold DEVICE
3. While holding DEVICE down, press ON/OFF and hold them both down until the LED turns on for that device.
4. Release both buttons.
5. Point the remote at the device, press and release PLAY and wait 5 seconds or until the LED stops flashing.
6. If the device does not turn off, then continue to press PLAY and wait the required interval (for a maximum of 20 times) until the device turns off.
7. When the device turns off, press REVERSE, wait two seconds and continue doing this until the device turns back on.
8. To finish programming, press and hold STOP until the LED turns off.
Anonymous
  • 74 Answers
  • Posted on Mar 25, 2008
You may be able to get the codes here free:
http://www.replacementremotes.com/tvcodes/index.html
dragonsthatk
Albert Getty
  • 547 Answers
  • Posted on Feb 12, 2009
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
1helpful
Does my Emerson LCD TV/DVD combination model LD195EM8 7 have a internal QAM tuner?
The Emerson LD195EM8 7 does not have a QAM tuner. It just has the ATSC (digital OTA) and NTSC (analog OTA and cable) tuners. Emerson TVs are manufactured by Funai. You can find most of their manuals here: http://www.emersonaudiovideo.com/support/download.php . Enter your model number without the 7 to find the download link; the direct link is hidden in the Java script. Sears Parts Direct also has the manual. The direct link to the LD195EM8 manual is http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/L0810491.pdf .
I wish that I had better news for you. I hope this helps.
Problem w/gpx td2420b 24"class tv/dvd combo---insert dvd & message indicates it reading and displays message err dvd ( this is w/ store purchased dvd)
Check and replace its laser pickup unit. Contact any service technician. The has to be opened to get the DVD mechanism out from the TV to get this part replaced. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Emerson lcd tv w/ dvd 19"
Contact the authorized service center for Emerson. The main board to your TV is faulty. A replacement should be done. Gopakumar Gopalan Google
3helpful
I have an emerson lc195emx, and can not seem to program my Vizio universal remote to sync with it. None of the codes provided work. Any help would be appreciated.
I have a 19" Emerson combination TV/DVD model LD195 EMX.
Since purchasing it I have been unable to program my Dish Network remote. Can't seem to find the proper code. Can you tell my what code or codes will work? Dish provides a list in a code book that accompanies their remote, but so far none seem to work. Please, HELP if you can.
I have an Emerson TV w/dvd player model LD190em1 but do not have a remote with it. Can I purchase a remote from you?
Actually, this site is a technical advisory site, and they don't supply equipment, just advice.
You can go to Radio Shack or Walmart or Best Buy and get a Universal Remote, that can be programmed to your TV.
Follow the instructions to program the remote to your make and model TV.
Good luck, and hope this helps.
5helpful
2answers
Need remote code for emerson LC195emx LCD TV to program my uverse remote. ATT codes don't work. Thanks
hi! i have here a couple of codes for your emerson tv. you could try them 0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037 hope it would work! goodluck!
2answers
I need to program my at&t uverse remote with the Emerson 19 inch TV/DVD. I do not have a code.
i install uverse, the auto seek is done by hit and hold TV and OK. wait for lights to flash enter 900 and push play over and over SLOWLY and when the tv turns off, press enter.
NOTE: some tvs WILL NOT program to our remotes
1helpful
No code for the Emerson tv, dvd combo, model #LD200EM8
i have a remote and i can't find or program it to my tv combo tv/dvd
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
