Mantis 2-Cycle Tiller Logo
A
Alex kalanihuia Posted on May 14, 2014
My troybilt TB146ec doesn't fire - Mantis 2-Cycle Tiller
I Have A Troy Bilt Pony 42" Deck How Long Is The Deck Belt Inch Wise
Most TroyBilt mowers conveniently have belt part numbers on a label underneath the hood. Enter the part number at TroyBilt parts page https://www.troybilt.com/equipment/troybilt/OwnersCenterLandingView?catalogId=14102&langId=-1&storeId=10001 and it will likely have belt length in the description.
Apr 22, 2019 • Troy Garden
How to replace gas lines on the tb146ec cultivator.
Hi Robert:
Sounds like a matter of removing the old lines and installing new ones.
Work safe! Drain fuel from tank first.
Replace the pull cord on a tb146ec video
I am dying to do this, there is no info on it anywhere
What else could cause my troybilt cultivator to not run?
spay starting fluid in the air filter if it fires then you have a carb/fuel problem (keep in mind small engines need fuel 30 days or newer )if no fire on starting fluid check for spark if you have spark good fresh fuel remove the muffler and try it again if it runs with the muffler off then open the muffler and clean the screen iside
Troybilt mower want start. Model # 37120 13AN689G766 Serial #1C244B30107 002?
try and jump start it with your car then check the safety switches if jumping doesn't help
Troybilt 6.5 wont start without some help
Check to see of where the canles connect to the linkage, there are usually thumb nuts you can adjust similiar to that of the brakes on a bicycle handle bar.
Top Mantis Garden Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Mantis Garden Expert? Answer questions, earn points and help others
