Washing Machines Logo
A
Anonymous Posted on May 14, 2014
Replaceing tub bearings
Lgh1642dso
  • Official Brand Answer 2,267 Answers
  • Posted on May 16, 2014
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1289850
Points
2557
Good Morning Friend,
I understand that you want to replace the tub bearings in your laundry center, model# LGH1642DS0. Typically, this is not a do it yourself repair. There are no manuals that will guide you in replacing the tub bearings. I suggest contacting your local authorized technician for further assistance. They have had the necessary training to replace the bearings with ease. Should you have any other questions, please feel free to reconnect. Hope this is helpful.
-Best Regards-
WP
Crosley washing machine making a clicking noise when I turn it on.. Machine won't do anything ?
(1) The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, i recommend replacing both the outer tub and bearing.
My whirlpool duet front load washer has loose fins in the tub. how do i tighten them??
You're not gonna like this:
Pull the washer tub (see elsewhere on FixYa for step-by-steps), split the tub by removing the screws holding the two halves together, and remove the inner tub. Bend any tabs tighter that hold the fins on, and tighten any screws. While you have it apart, check for grease stains or other leakage on either side of the outer tub, and ensure the inner tub bearing is tight so that the inner tub shaft rotates smoothly and without oscillation. If there are stains or if the bearing is showing wear, replace that (back) half of the outer tub to replace the bearing (unless this is one of the few machines that allow you to replace only the bearing). You don't want to put all this back together, only to have to take it all apart again when the inner tub starts hammering on the inner tub because the bearing went south.
2helpful
What type of bearingsare used in Clothes dryer drive motors. i.e. Whirlpool
Motors have sealed bearings which it is cheaper to replace the motor. If you are hearing sound like this it may be your Tub bearing or one of the tub roller bearings these are like roller skate wheels they lay at each side under the dryers tub so it rolls smoothly and not many dryers use rear bearings anymore so look into the rollers and new tub seals or tub holder. The motors rarely fail in the bearing department and if they do a new motor is required.Remember to rate my solution and give testimonial it is how i earn my achievements Thanks in advance.
1helpful
Water keeps getting into my bearing.
I feel you have a Tub Seal leak.
Did you replace the Clutch Pulley or a repair service?
You are talking about the Clutch Pulley One-Way Roller Clutch bearing in the white bearring plate correct? The First two digits of your serial number are 12 thru 17. What are the first two digits of your serial number?
To replace the Tub Seal you need to remove the spinner assembly. That means you have to remove the outer tub. A bigger job but several on this forum have completed it including myself two weeks ago on a Series 10 FAV6800A.
I will point you to a link most recently where a form member replaced Outer tub bearings on his Series 15. If your wash basket spins up to 850 rpm with no Outer Tub bearing noise I would just do a tub seal replacement this round.
You would need the Tub seal see Sears Parts Direct. I would also pick up the Tranny O-ring seal (series 10) .
Some links on Outer Tub Bearing replacement.
http://www.fixya.com/support/t3973659-fav6800aw_sn_15_top_loader_r_nunit
http://www.fixya.com/support/t4028403-just_replaced_new_clutch_fav9800aww
If you replace the tub seal make sure you remove this sleeve that will more than likely stay on the Spinner Support when you remove. See Page 49 of the Service Manual. Here is a real world pic of the sleeve on the Spinner Assembly.
I did break off a Spinner Bolt even after heavy soaking in Liquid Wrench be careful;
There should be six there oops!
Good luck and post back if I can help.....Rich
2helpful
3answers
Looking for replacement bearings for the outer tub to inner tub on our Maytag FAV6800AWW, S/N 13389034ET. Don't want to replace the whole outer tub assy.
It sounds like you may have to replace the Outer Tub to replace the Outer Tub bearing .....ain't that just peachy.....good job Maytag design team.
If you are the original owner I would press Maytag hard to replace the Outer Tub based on the Outer tub Bearing failure. Their warranty states third thru tenth year Drive Motor, Outer Tub and Sealed Transmission. I’m sure you will need to have a certified Maytag repair service tech certify the failure and fix action required. Why should an Outer Tub bearing replacement cost you $430. Another poor design issue of this machine.
1helpful
Outer tub bearings are gone
My bearings went out too and I found this site http://www.neptunebearing.com/ Ordered the bearings and the Tony Tool. My son and I replaced the bearings in about 2 hours!
2answers
Whirlpool ghw9100lw2 bearing repair
It is not a hard job to replace the tub. Just time consuming. I replaced the back portion of the tub where the bearing is. If the inner tub shaft has any wear on it , replace that as well. Otherwise youll have the same problem in a month. Its an easy fix if your patient. I paid about $130.00 for the rear portion of the tub. I'm not sure about the inner tub.
Clothes
If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly and the outer shell with the tub bearing.
check out for this link
http://www.applianceaid.com/frigidaire_frontload_washer.html#noise
thanks.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
