There is no cold water coming out on any setting on my whirlpool ultimate care ii washing machine. hose is clear and flows fine.
SOURCE: Whirlpool Ultimate Care II washing maching but will not spin.
lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
SOURCE: Ultimate Care II - Rinse Cycle does not start
sounds like a lid switch problem. is there a clicking noise when you open and close the lid?
if not then the lid switch may need to be replaced; inexpensive.
this could also be caused by a bad timer.
also try a different speed for the rinse cycle, it may be a bad motor and it is not going into a certain speed. instead of gentle or slow speed try fast or normal, something like that.
SOURCE: Whirlpool Ultimate Care 2 leak after wash cycle
Hello, you may have a small drip from the pump or a small drip from the hose that goes from the pump to the rear of the cabinet. To make sure you will have to run the unit with the cabinet removed. A local service tech can remove the cabinet quicklyand isolate the leak.
SOURCE: How to separate auger from agitator. whirlpool ultimate care II
When you look down into the agitator, are there 4 white plastic points that look slightly melted or otherwise deformed? If so, using a small flat head screw and a small hammer, separate the white plastic from the surrounding translucent plastic. Once you've done that, it should easily pull apart.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
