Check valve lash. Most common symptom for small engines is exactly what you explained
Make sure that the oil level is not too high. If the blade hit something, it will change the engine timing,which will cause the handle to pull like that. To check to see if the shaft is bent, UNPLUG the spark plug wire!!! Turn the mower on it's side (KEEP the carb side up!)Pull the rope and have a helper watch the shaft. If it's bent, buy a new engine, It will cast about $120-$180 to rebuild the old engine.
