SOURCE: I have a Hoover 550 MB Top Loader washing machine
Will the unit spin if you manually turn the timer dial to spin? If so, remove power, remove the clock motor from the timer, and inspect the clock and mating timer gearing for debris or damaged gear teeth. At the worst, replace the timer. You may be able to scrape or file the damaged teeth so that the timer will progress.
Testimonial: "That is great advice . Will try and see if your solution works . cheers"
SOURCE: Does the hoover 200m 4.4kg top loading washing
Hi just read your posting.It should be in the center of the agitator.Pull the center out and there should be a lint bag attached to it.Unfortunately they do not stop much lint from getting on the clothes.Hope this helps and please reply if you need more help.
