The driver is installed, but has ! mark by it, won't download my pictures from Kodak easy share z710 camera to my computer won't reinstall driver when I uninstall
Did you try to reinstall the complete easy share software from Kodak? Just a driver is not enough. The software is on the cd that came with the camera,. Or you could try to download it from the Kodak site. I think your camera has to be registered,but you could do that if they ask. If that does not work, you could install photoshop elements or gimp.
your computer needs the software, not only a driver.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
SOURCE: UNINSTALLING KODAK EASY SHARE SOFTWARE and removing it on my system
im having the same problem.
SOURCE: Cannot download pictures from camera to computer
What system Are You Using? Im Using windows Seven And Vista, It Will Not Work . Just Use Sd card Reader Or Flash Usb Sd reader.
SOURCE: Can't install KODAK Easy share c613 digital camera
The current (VISTA compatible) Easyshare software is available for a free download at
www.kodak.com
SOURCE: How to download pics. from my camera to my computer
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card?
Answer :
Follow these steps:
When you have finished copying pictures, reset the Image Storage location to your original setting.
Once your pictures are transferred to the SD card it will be easy to transferre onto the computer.
