All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.
or this.
iFixitMine won't turn on or charge either and it is a samsung galaxy tab 2 7.0 and I'm surprised so many people are having the same problem and I need help.
Basically, if you have to try and establish "IF" the charging system is at fault or yor Tab 2 device by substitution method.
By substitution method I mean try your charging accessory(s) on a friends working Tab 2 or product that uses same cable connection and or theirs on yours.
I can't quite fathom two of them can have same problem i.e.Tab 2 devices BUT can understand if you ONLY tried 2 different cables and NOT the USB power supply that regulates the electricity, meaning I doubt you're refering to TWO Tab 2's being faulty, but rather charging system made up of plug pack with USB connector and USB cable to Samsung Port connector.
either your battery is shot as in dead or your charger is faulty
you could try to charge it using a usb lead in your computer or another usb port to see if that works , or try another charger to eliminate your lead /charger you are using
try to use the USB part and charge it with ur laptop. Make sure ur tab is turned off or else it wont charge.I had d same problem and doing this temporarily till I get it permanentaly solved. But this does work.
