On the control panel we are not able to switch from ice to water...changed the control panel, still not working...all the other lights are working well. Tried to reset door lock button, is working but it jumpes by unlocking again to ice macker...(ice maker is working). What could that be and how can we resolve that issue? Thank you very much for any help!
If the refrigerator water dispenser is not working the water supply tube in the door may be frozen. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined, third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch, when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
SOURCE: None of the buttons on the door will not work
Hi!! You should be able to unlock it from the dispenser control panel if not disconnect the frig for 5 minutes from the back of the wall and try again..Good luck..
SOURCE: Maytag MFI2568AES Stainless Steel Bottom
sounds as if the icemaker is getting too much water and causing the unit to flood out. aside from replacing the icemaker you may be able to adj the amount of water going into the icemaker. there is a screw that holds the front cover of the icemaker inplace. remove the cover and you should see a screw with a + and - sign on it. try turning the screw 1/4 turn then wait for the icemaker to cycle and see if it improves. keep making theses adjustments until your problem is solved thx peyton
SOURCE: control panel on my fridge
Pull the power cord for 5 minute to reset the control board. if this control panel malfunction still exist after the reset, replace the control circuit board.
This is a typical control fault that should be corrected by pulling power for 5 minutes. if not, this reset will confirm major damaged to the circuit board.
SOURCE: Maytag MFI2266AEU Water and ice dispenser locked, control panel
Door Panel Locked
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue pressing Freezer "-". You will see PE _ _ _ _.
Press Freezer "-" until PE # # # # shows on the panel.
Using Freezer "+" to move cursor, Refrigerator "+" and "-" to change numbers, bring all numbers to "0". Press Freezer "-" until PE and numbers blink. Unplug refrigerator for 45 seconds, never beyond 1 minute or you'll have to start over.
Look inside refrigerator door and locate the serial sticker. To the right of the serial number is the CODE ####. Plug in your refrigerator.
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue to press Freezer "-". Using the same method as above, enter the four digit CODE number you found on the serial sticker. Press Freezer "-" until PE and numbers blink. You have just reset your panel. Unplug for 45 seconds. Plug in refrigerator and you should now have full use of your door panel.
This unit has a built in safety timer mechanism. If it dispenses water for two minutes, it assumes it is flooding your house and shuts the panel down. If you are filling a pitcher of water, just stop dispensing halfway through to reset the safety timer.
SOURCE: I don't know how to turn on the door panel
I had same issue. The control panel had been set to Sabbath mode. Hold down the "DOOR ALARM" button for 3 seconds. Then lights will turn on on both display windows. Scroll using the + and/or - sign on the left side display until "SAB" is shown. Then scroll using the + or - sign on the right side display until OFF is shown. Finally, hold the "DOOR ALARM" button down again for 3 seconds. All should be good to go!
