When the monitor first comes on it displays xp logo then goes blank then shows welcome screen then either shows desktop and goes blank or just goes blank. green light stays on. To get it to work properly requires rebooting 2 to 3 times as well as sometimes having to turn it off and on several times over a 5 to 15 minute period. once it seems to have warmed up it works fine and Ican turn the system off and on with no problem as long as the off period does not exceed 15 to30 minutes.
when i boot up xp, my monitor goes blank after seeing the HP blue screen where it gives the options for F9 boot menu, F10 Setup, F12 Boot from Lan, I tryed all nothing pops up. I need to know how to change to VGA mode, even safemode wont boot!
when the monitor first comes on it displays xp logo then goes blank then shows welcome screen then either shows desktop and goes blank or just goes blank. green light stays on.
Hi Both, what was the solution identified could you please kindly post the same ?
When I tried to go into safe mode it took almost 45 minutes just to get to the sign in screen! I finally got it running (extremely slow), and tried to make Backup Recovery disks, but after ripping Disk 1 it shows: Error code: 0x9411 Verify failed. Please insert a blank DVD into the optical drive and press OK. 7 disks later.... here I am!
