How to find galaxy tab gt p1000
SOURCE: Can Samsung GT-P1000 Galaxy TAB update to android
YOU CAN GET UN OFFICIAL MOD I.E FOR ANDROID 2.3 ON YOUR GALAXY TAB.
ANDROID 3.0 IS AN DIFFERENT O/S ALTOGETHER AS IT REQUIRES DUAL CORE PROCESSORS.
TRY IN FOR SAMSUNG TAB 10.1
SOURCE: Hi, i m not able to find the motion sensor
its in notification panel by the name orientation lock.
SOURCE: Hi, i have Galaxy Tab model
Install these drivers http://firon.net/xda/Samsung_Mobile_Driver_V1.3.800_For_SPH-d700_Epic_4G.zip for windows 32bit
this should fix your problem
SOURCE: My samsung Galaxy Tab GT
Somehow this is related to the SD card. I had replaced the original 2 GB SD card with 8 GB one and it was working fine. I used to use the flash as a torch by using the record function with flash and then pause which leaves the flash ON to be used as torchlight. But then it broke down displaying Camera failed. I did lots of troubleshooting but it didnt work, finally I inserted the original SD card back and the cam started working. Try this:Switch Cam Storage to SD card then remove the SD card from the cell and reboot the cell without the card. let the cell work for few mins(30 to 60mins)without the SD card. Now insert the SD card and reboot the cell. wait for few mins and check. Replacing the SD card from another cell may also work.Good luck
