Not sure if you solved this one yet..but ...
d5 - Door is open during washing
I have some more codes for a Model # MAH6700AW if you need them.
E2 - a button has been pushed for more than 30 seconds
dc - unbalanced load prevented the washer from spinning
dL - door is unlocked when washer is running
d5 - door is open when washer is running
FL - the washer failed to lock the door
Hr - water temperature control problem (Heater control problem)
LE - the washer has tried to fill but has not reached the proper water level
LO - the door will not unlock
E3 - motor not running properly
nd - the washer is not draining
nF - the washer has tried to fill but was unsuccessful
Sr - problem with control
PF - electri service was lost when washer was running
Book says for any codes not listed to call Maytag Customer service 1-800-688-9900
Check the latch on the washer door which locks into the washer. I found that latch (cheap plastic) piece was cracked from repeated opening and closing.
Thank you for your help. I wonder if the latch is defective. Sometimes I get it and sometimes not. I'll take what ever codes you can give for future reference.
M
I have a code E2 that is not allowing the machine to rinse and spin. Does anybody know how to fix this.
Rick
F-15 anyone know what it is?
what does the code OF MEAM
Code DO
